MKV file seek freeze mpc-hc/xbmc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-22-2013, 08:15 PM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
so i have an annoying issue
if i seek MKVs too many times(depending on each file i guess, from 2GB x264s with AC3 to 40GB AVC/VC1/etc with DTSHD/TRUEHD/DTS/AC3) it freezes the player (mpc-hc,mpc-be,xbmc, but not VLC) after 2-20 seeks/chapter changes/clicking randomly on the seek bar... i can let it wait for 10-30 seconds sometimes it starts playing again...
tried switching the file(s) to other HDDs/SSDs didnt help, tried changing audio out to speakers not spdif without help... any other ideas?
display - vizio p65
AVR x4300h +lepai 2ch amp = 7.2.4
L/C/R - Chane 2.4, SURROUND - dayton 3in cubes *temporary
BASS - 2x Seaton F18, MBM - 2x Behringer 1200
2100 ft^3
bulls is offline
post #2 of 12 Old 01-23-2013, 08:58 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Can you elaborate on your HTPC set up hardware and if these are over a network or local HDD?
Sammy2 is offline
post #3 of 12 Old 01-23-2013, 03:20 PM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
i7-870, 8GB ram, ATI 5670-hdmi out,
sound: mobo asus onboard spdif out
win 7pro 64
using mpc, tried 32 & 64bit, internal filters, tried gabest & haali before
local playback
display - vizio p65
2100 ft^3
bulls is offline
post #4 of 12 Old 01-23-2013, 03:36 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Try LAV. You could use the Shark007 installer set to recommended settings. There's an installation guide for this on his website that is the same guide that is on assassin's website.
Sammy2 is offline
post #5 of 12 Old 01-23-2013, 05:18 PM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
tried Shark before, just tried LAV again and it seemed to make it take longer until freeze... problem is i cant set LAV to work in XBMC ...
display - vizio p65
2100 ft^3
bulls is offline
post #6 of 12 Old 01-23-2013, 05:53 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Can you re-rip the mkv from the original disc?
What did you use to rip this content to mkv?
Have you tried playing it with something else like WMC or WMP?
Can you try a different mkv?
Sammy2 is offline
post #7 of 12 Old 01-23-2013, 05:53 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Sammy2 is offline
post #8 of 12 Old 10-15-2013, 06:47 PM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
omg im gonna shoot this computer, what the heck does it want???
im still having this issue, if played in XBMC/MPC and skip forward a few times, it would freeze for a 5-10 seconds, mostly on large files 15GB or more
i got a new receiver and it didnt help either (i thought it was because maybe not able to sync audio optical with hdmi vid), but its still doing it with a-v passing thru hdmi to receiver...
im beginning to think its some mobo sata issue ... these files play fine on a lower spec laptop, but they would freeze if played over network on same laptop
although copying files gives me no errors, and HDD diagnostics have no errors... this is on 3 different HDDs
display - vizio p65
2100 ft^3
bulls is offline
post #9 of 12 Old 10-28-2013, 03:11 PM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
well. kind of shot it. got a new mobo z87, mem, cpu ... and ... new 4TB HDD(same manuf-seagate)
it does the same ... seek a large video file 2-3 times and bam, freezes... tried same file on a SSD and bam, no freeze this time. ... so maybe some kind of random seek limitation of these large HDDs ? NCQ issue on the drive ? is defragmentation possible cause?
display - vizio p65
2100 ft^3
bulls is offline
post #10 of 12 Old 10-28-2013, 05:36 PM
Dark_Slayer's Avatar
Quoted: 722 Post(s)
Liked: 451
I don't have this experience at all. I use ff/rw a lot during mkv playback (usually while watching tv shows with wife). What do you mean for seek?
Are you using a remote or keyboard? Do you mean 5 / 15 second skips ( -> or arrow key)? Or just the simple "F" or >> key for fast forward in XBMC? Chapter skips with the >>| remote button or ctrl+shift+f? Typing a specific numeric time and pressing "play" to skip to that point of the video?
FYI - just did all of these 3 times a piece without a hitch during playback of a Tron Legacy mkv. I cannot reproduce the error
Dark_Slayer is offline
post #11 of 12 Old 10-28-2013, 06:22 PM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
in XBMC using chapter skips
in MPC/potplayer using clicking on the seekbar
display - vizio p65
2100 ft^3
bulls is offline
post #12 of 12 Old 10-31-2013, 11:12 AM - Thread Starter
bulls's Avatar
Quoted: 150 Post(s)
Liked: 88
ok ok hold on, i, i , i think its working now, no freezzing !
either 1 of 2 things or a combination under the full moon... installed an old 3tb drive ... and also installed the Intel Rapid Storage software (no changes made in it, just installed)...
edit: think this Intel Rapid Storage is also doing some cache thing, 2G file transfer SSD-> HDD 3 sec ... i dont think so, lol.
display - vizio p65
2100 ft^3
bulls is offline
Reply Home Theater Computers
