WHS2011 server randomly shutting down - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-24-2013, 07:02 AM - Thread Starter
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
So this is pretty frustrating. My WHS2011 machine is just randomly shutting after running for a few hours. I'm just wondering where to begin. Maybe it's BSODing? Is there some place I can find those reports?
lockdown571 is online now
post #2 of 15 Old 01-24-2013, 07:06 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
If it's "BSODing", when it starts up next time, Windows should say something like "Windows has recovered from an unexpected..." and allow you to see which device/driver caused it.
If it's just shutting down.....there's gotta be a Scheduled task/process/action/motherboard BIOS setting or "something" that's shutting it down.
kapone is offline
post #3 of 15 Old 01-24-2013, 07:08 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 87
If the latter is the case, is there someplace I can look that tells me what process shut down the computer? I know there's a 'lastwake' feature in command prompt.
post #4 of 15 Old 01-24-2013, 07:10 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Lastwake is only for waking from sleep.
Start combing through your Event Viewer/Scheduled Task library/Motherboard BIOS settings. Failing that, start looking at each program/process you have installed (apart from Windows) that may be scheduled to "shut down" when it's "done".
No easy answer, I'm afraid.
kapone is offline
post #5 of 15 Old 01-24-2013, 07:29 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 87
Thanks for the help. After boot I just get the Windows wasn't shut down properly message. On another boot it just immediately shut off even before loading the log in screen. I suspect it's hardware/driver related. I installed a new NIC a couple of weeks ago, I'm going to try removing that and see what happens.
post #6 of 15 Old 01-24-2013, 07:36 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Yup. That's the key. Hardware/Driver issue.
kapone is offline
post #7 of 15 Old 01-24-2013, 10:47 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 87
I'm fairly certain this was related to the drivers I installed for an Intel NIC. I removed the NIC and the WHS 2011 machine has been running fine all morning. I remembered I had a lot of trouble finding the right drivers, so I probably installed the wrong ones. Funny it ran fine for about 2 weeks.
So I guess my question now is, anyone know if there are proper WHS 2011 drivers for an Intel PWLA8391GTBLK PRO/1000 GT NIC?
post #8 of 15 Old 01-24-2013, 04:39 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Glad to hear everything is working
I had a somewhat finicky motherboard that wouldn't finish POST and boot the OS without me pressing F1 on a USB connected keyboard (this was after I changed graphics card)
I finally combed through the BIOS settings and found an option to Alert, Shutdown, or Resume after HW check. I really can't remember the exact wording, but I changed it to resume and never had a problem
Also, I was trying to move some old parts to a new case and experienced the same thing you described 3 times while trying to load OpenELEC onto a usb flash drive. I assumed it was having trouble (old bios, old hardware) continuing without an attached HDD. Then everything finally installed and booted, then shutoff
After much troubleshooting, I found that the cpu cooler wasn't staying seated. Swapped it out, no problem since (actually gave it away, but the recipient hasn't called me so no problems yet at least rolleyes.gif)
Dark_Slayer is offline
post #9 of 15 Old 01-24-2013, 04:41 PM
Quoted: 655 Post(s)
Liked: 434
Actually, I guess everything is not running fine, and I can't answer the WHS driver question smile.gif
post #10 of 15 Old 01-24-2013, 08:18 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
The ones windows supplies are the proper drivers.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18268&lang=eng&OSVersion=Windows%20Server%202008%20R2%20Standard*&DownloadType=Drivers
Andy_Steb is offline
post #11 of 15 Old 01-24-2013, 08:35 PM
sycochkn's Avatar
In the past 20 years or so. I have most commonly experienced random shutdowns due to bad power supply (overheating, poor voltage regulation or bad power connection at the MB) or CPU overheating (dirty heatsink or bad fan). Once due to the order in which I installed some hardware drivers. Overheating also eventually compromises the connections from the CPU socket to the system board. Hardware or software. Who knows?
sycochkn is offline
post #12 of 15 Old 01-24-2013, 08:36 PM
sycochkn's Avatar
sycochkn is offline
post #13 of 15 Old 01-24-2013, 10:24 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 87
Does that mean it should have worked out of the box? That definitely wasn't the case. Maybe I had to get them through Windows update?
post #14 of 15 Old 01-25-2013, 09:42 AM
duff99's Avatar
I would agree with this. I just experienced a similar problem with a WHS V 1. box. It turned out to be the power supply. This has been the problem with other systems in the past also.
duff99 is offline
post #15 of 15 Old 01-25-2013, 05:36 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
I'm pretty sure it worked out of the box. As you can see I have no option to roll back.
I remember with WHS v1 I was able to download newer drivers from Intel, but not with 2011
I know there is also a problem with some of the motherboard Intel Nics and WHS2011. I think you have to do an INF hack to install drivers.
Reply Home Theater Computers
