OTA HD tuner recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 01-25-2013, 10:15 AM - Thread Starter
jekbrown's Avatar
Hi gang, I need a way to bring OTA HD into my HTPC. Don't need cable card capability or anything like that, just 2 or more OTA HD tuners. What are my options? I need to:
1. watch/record OTA HD on my main tv (where the HTPC is)
2. watch/record OTA HD on my bedroom tv (where the xbox will be, most likely via a wired network connection.)
3. watch DVR'd OTA HD shows
I have windows 8 and media center on my HTPC. It can handle all the DVR programing etc for me, correct?
jekbrown is offline
post #2 of 44 Old 01-25-2013, 10:44 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
Here are probably your best choices for ATSC dual tuners for your Media Center PC:
SiliconDust HDHomeRun Dual
Hauppauge WinTV-HVR-2250
AverMedia A188 Duet
captain_video is offline
post #3 of 44 Old 01-25-2013, 11:14 AM - Thread Starter
jekbrown's Avatar
thanks for the suggestions! Are there pros/cons of using an internal card over a networked model like the silicondust one?
jekbrown is offline
post #4 of 44 Old 01-25-2013, 11:24 AM
lockdown571's Avatar
Quoted: 65 Post(s)
Liked: 92
Networked tuners are just easier and more flexible IMO. Hook it up to your network and you're done.
lockdown571 is offline
post #5 of 44 Old 01-25-2013, 11:30 AM
Zagor's Avatar
I Agree with this. Network tuners are so flexible that you can actually assign one tuner to one PC and the other to a differenct PC so you can have live TV in two seperate locations.
Zagor is offline
post #6 of 44 Old 01-25-2013, 11:42 AM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
I got the Silicondust dual and it has a weaker tuner than my other hauppauge internal tuners. Probably b/c it splits internally. It won't pick up a few of my distant channels very well. If all of your channels have a strong signal it may not matter though. I wish it had 2 antenna inputs instead of just 1 which gets split.
squeakybirnbaum is offline
post #7 of 44 Old 01-25-2013, 12:07 PM
Zagor's Avatar
I have the original hdhomerun and it does have dual antenna inputs. I have to use my own splitter to split the signal coming from the antenna. Unless you plan on using two antennae, you will have to split the signal at some point to feed each tuner.
Zagor is offline
post #8 of 44 Old 01-25-2013, 12:09 PM - Thread Starter
jekbrown's Avatar
probably a dumb question, but is there a simple way to boost the signal from an antenna to compensate for this problem?
jekbrown is offline
post #9 of 44 Old 01-25-2013, 12:37 PM
DanPackMan's Avatar
Quoted: 299 Post(s)
Liked: 575
You can try a drop amp or other type of tv signal amp. Just make sure to get one that supports the ATSC, not one of the old NTSC amps. Might not be good to use one in conjunction with a two antenna input. You typically want the amp as close to the antenna as possible.
DanPackMan is online now
post #10 of 44 Old 01-25-2013, 12:57 PM
Zagor's Avatar
I use this http://www.amazon.com/gp/product/B001EKCGT8/ref=oh_details_o03_s00_i00 it works great.
Zagor is offline
post #11 of 44 Old 01-25-2013, 01:18 PM
akadoublej's Avatar
Quoted: 28 Post(s)
Does anyone make an OTA HD tuner with HDMI out? A friend of mine broke the HDMI port on his Samsung tuner and is looking to replace the tuner under the assumption it will be either not possible or too costly to repair.
akadoublej is offline
post #12 of 44 Old 01-25-2013, 01:26 PM
Quoted: 524 Post(s)
Liked: 341
Not quite. You have to install the SiliconDust HDHomeRun software on each computer you want to have access to the tuners. Then, if you're using Windows Media Center, you have to run the TV signal setup so it will configure the tuners for use.
FWIW, the Hauppauge 2250 tuners have internal splitters. In fact, any internal dual tuner model with a single coax input will have an internal splitter. On the subject of signal strength, I concur the the HDHomeRun tuners tend to have a slightly lower signal strength than either the Hauppauge 2250 or the AverMedia Duet. I use all three in case you're wondering. I'm in an area that's close to the broadcast towers so the difference in signal strength is irrelevant for my setup. If you're in a fringe area it may make a difference.
post #13 of 44 Old 01-25-2013, 04:11 PM
Quoted: 65 Post(s)
Liked: 92
I was mostly referring to the hardware aspect. You don't have to open up the computer case. Don't have to worry about half height vs. full height pci slots. You can use it with a laptop (which is what I do). You can place it anywhere on your network, doesn't have to tied to a specific computer, etc.
The HDHomerun essentially turns your LAN into a cable distribution system. To use it on a computer you will still need software/drivers installed, although with the new DLNA function on the Prime, you hardly need that (you just need a computer for the initial setup).
post #14 of 44 Old 01-25-2013, 04:47 PM - Thread Starter
jekbrown's Avatar
Based on what I'm reading, the SiliconDust unit seems to be the one for me. The only question left is, does anyone know of a way to get a better price than what B&H is offering? ($85.xx shipped)
http://www.bhphotovideo.com/c/product/764007-REG/SiliconDust_HDHR3_US_HDHR3_US_HDHomeRun_Dual_TV.html
jekbrown is offline
post #15 of 44 Old 01-25-2013, 05:01 PM
Quoted: 65 Post(s)
Liked: 92
It goes on sale frequently. I think I saw it for $65 the other day.
post #16 of 44 Old 01-25-2013, 05:07 PM - Thread Starter
jekbrown's Avatar
on sale generally or at a specific site or two? It's worth it to me to wait...my Dish Network bill is paid for another month anyway! smile.gif
jekbrown is offline
post #17 of 44 Old 01-25-2013, 05:08 PM
jeffkro's Avatar
jeffkro is offline
post #18 of 44 Old 01-25-2013, 05:29 PM
Quoted: 524 Post(s)
Liked: 341
You could probably pick up a DirecTV HR10-250 HDTivo for next to nothing. It works as an OTA ATSC tuner without a subscription and it has HDMI out. Just make sure it has a working HDMI port as the earlier models had issues with them failing. The only caveat is that you need a DirecTV dish to download the guide data. It has an ethernet connector and you can get it to connect to Tivo Inc. manually or automatically, but I don't think it will acquire guide data via the internet.
Aside from that, there are other OTA HD tuners that were marketed once upon a time from various vendors like LG, Sony, and a few others. Check out ebay or Craigs List. I spotted a few listings for the LG LST-4600A tuner selling for $50 with free shipping. No HDMI out but it does have DVI and digital audio out.
post #19 of 44 Old 01-25-2013, 07:23 PM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
This may be a matter of person preference.
I did not use a HDHomeRun because I would have needed somewhere to put the unit & also another power outlet to plug it in. Then I would have needed an Ethernet switch in order to provide another network connection for the HDHomeRun. And of course a place to put the switch & yet another power outlet for it.
I went with an AverMedia Duet card because it's inside the HTPC & adds no additional black boxes to my setup.
gonzo90017 likes this.
Mike99 is offline
post #20 of 44 Old 01-26-2013, 05:28 AM
Quoted: 524 Post(s)
Liked: 341
The HDHomeRun is better suited for a situation where you need to share tuners with more than one PC or you have a limited number of PCI-e slots in your PC and don't want a USB tuner. If you have a slot available and you only need the tuner on one PC then an internal tuner makes more sense.
post #21 of 44 Old 01-26-2013, 05:45 AM
DanPackMan's Avatar
Quoted: 299 Post(s)
Liked: 575
Newegg, Amazon and TigerDirect are you best bets for sale watching. I've seen good HDHR prime sales on WOOT, but can't recall seeing the Dual there.
BTW, another possible advantage of a network tuner like HDHR is that it may allow you to locate it closer to an antenna, thereby reducing signal loss in the cable (if that is an issue).
post #22 of 44 Old 01-26-2013, 07:03 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I would still go with the external network device, because of what your next HTPC might look like. My next HTPC very well may be a very small footprint PC or even a notebook. Also, which do you think is more likely to be around in five years? Ethernet cabling or PCI-e slots in new computers? An external network device should have a longer useful life for that reason.
Karyk is offline
post #23 of 44 Old 01-26-2013, 08:11 AM
jeffkro's Avatar
Yup, Intel's Next Unit of Computing devices will probably wipe out the need to build our own HTPC's.
jeffkro is offline
post #24 of 44 Old 01-26-2013, 08:14 AM
jeffkro's Avatar
The only problem with this is that 1080p doesn't seem to work great over wifi, so you kind of need all your devices to be on a wired network.
jeffkro is offline
post #25 of 44 Old 01-26-2013, 09:52 AM - Thread Starter
jekbrown's Avatar
wired is fine. I won't be able to watch on my laptop I suppose, but I've never really wanted to anyway. So long as it works on my main TV (where the HTPC is with a wired connection) and my bedroom TV (where an Xbox 360 slim with a wired connection), I'm a happy camper. smile.gif
jekbrown is offline
post #26 of 44 Old 01-26-2013, 12:29 PM
Quoted: 524 Post(s)
Liked: 341
I agree that 1080p and WiFi don't play well, but what's that got to do with OTA tuners? You'll only get 720p or 1080i with an ATSC tuner so wireless may be adequate (although I'm also a proponent of wired networks for any kind of media).
post #27 of 44 Old 01-26-2013, 12:35 PM
Charles R's Avatar
Liked: 645
For the fun of it I tested streaming via my HDHomeRuns to my wife's laptop (via a very low-end wireless network) and it worked like a champ. OTA streams typically don't exceed 16Mbps (at least around here).
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #28 of 44 Old 01-27-2013, 12:35 AM
Quoted: 26 Post(s)
Liked: 26
I use 1 antenna with a distribution amp (1 in / 8 out) instead of using splitters. I have 4 single tuner Hauppauge 1800 tuners in my HTPC that all get great signal. With the HDHomerun Dual the signal is much worse.
post #29 of 44 Old 01-27-2013, 12:40 AM
Splicer010's Avatar
Liked: 40
Amps/boosters are a frequency range. any and all from average 50-1000MHz, type deal and are completely blind to ATSC/NTSC. wink.gif
Splicer010 is offline
post #30 of 44 Old 01-27-2013, 01:53 AM
blackcat6's Avatar
Quoted: 319 Post(s)
Liked: 70
There is no such thing. Amplification deals with the underlying RF carrier wave and for TV, the modulation, digital or analog, won't make any difference. Since ATSC tends to be mostly in the UHF spectrum, this is where the OP should focus. i.e. What is the UHF amplification.
blackcat6 is offline
Reply Home Theater Computers
