How to play computer speaker sounds through mic port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-26-2013, 10:45 AM - Thread Starter
Delta223's Avatar
Hi guys;
Audio amateur here. How can I play the sounds from my computer speakers through my microphone port:
1) With no loss in sound quality
2) While allowing me to have my regular microphone connected to the microphone port as usual
I run a Windows 7 laptop with only 1 microphone port and speaker port.
Delta223 is offline
post #2 of 5 Old 01-26-2013, 06:29 PM
jdanforth's Avatar
Liked: 25
You can't play audio through a microphone port.
Are you saying that you have a combination mic/speaker port like on an iPhone? If so then you need a breakout adapter of some kind.
Give us some more information.
jdanforth is offline
post #3 of 5 Old 01-26-2013, 07:51 PM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
smile.gif think i found it
http://www.howtogeek.com/howto/39532/how-to-enable-stereo-mix-in-windows-7-to-record-audio/
In my alienware laptop its called "rec playback" and not "stereo mix". i made that the default recording device.
that setting though only records what is played back and didnt pick up the mic. to pick up the mic, on the same recording tab, go to the properties of the device you normally have, go to the listen tab and check the listen to this device. one downside is that you will hear yourself too.
this was tested and works with analog headphone connections. i was testing with my usb headset, but had to go back to watching tv with the wife :P
if the usb headset could do this, the quality would be awesome. but what you say with the analog connections, there was a lot of extra environmental noise.
but looks like its possible without extra cables.
aliaskary77 is offline
post #4 of 5 Old 01-27-2013, 12:09 AM
sitlet's Avatar
Quoted: 16 Post(s)
You can't. A microphone port is an output port only.
sitlet is offline
post #5 of 5 Old 01-27-2013, 03:45 PM
captain_video's Avatar
Quoted: 529 Post(s)
Liked: 342
I think you meant to say it's an input only, not an output. A speaker jack is an output.wink.gif
OTOH, the OP's question is extremely confusing. Is he asking if he can play the output of his speakers as an input to his laptop via the microphone input? He never indicated which speakers he was referring to so it's possible he's talking about the speakers in his stereo system.
OP - what exactly are you trying to accomplish here?
captain_video is offline
Reply Home Theater Computers
