Lock screen and plex server issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-28-2013, 05:18 AM - Thread Starter
BobBart's Avatar
I have my htpc connected thru hdmi to my receiver then to my tv. If I change inputs on my receiver and keep the htpc running it goes to a lock screen because it doesn't sense a monitor. Problem is I need to keep it running so others can use the plex server. Is there a way to eliminate the lock screen?
BobBart is offline
post #2 of 2 Old 01-28-2013, 08:24 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Odd, I don't think Windows normally logs you out if the monitor turns off. Do you have a screen saver enabled? Also, in power settings in the Windows control panel, do you have "require password on wake up" enabled?
lockdown571 is online now
Reply Home Theater Computers
