Live TV and Playback while still Recording Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-28-2013, 06:47 PM - Thread Starter
hockeyrcks9901's Avatar
Hopefully someone can help...
My recordings work perfectly fine but live tv just shows a blank blue screen and trying to play a show that's still recording gives a corrupt video error. It still records fine.
Anybody experience this before.
Using network ceton tuner but I don't think that's the cause...
hockeyrcks9901 is offline
post #2 of 9 Old 01-28-2013, 07:36 PM
Puwaha's Avatar
Liked: 35
Have you installed any codec packs? Did you change the default MPEG2 codec from the standard Microsoft provided one?
Puwaha is offline
post #3 of 9 Old 01-29-2013, 01:49 AM - Thread Starter
Sharks codecs.
Don't think I changed anything on the MPEG settings.
post #4 of 9 Old 01-29-2013, 06:40 AM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
Originally Posted by hockeyrcks9901 View Post
Sharks codecs.
It is easy enough to uninstall the codecs (restoring OS defaults) to ensure that they arent affecting your problem. You dont need them for LiveTV functionality. Is your system 32bit? I ask because it is quite possible some other software installation has installed additional codecs. 'Format Factory' is a well known source of codec issues.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #5 of 9 Old 01-29-2013, 08:44 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 413
Sharks codecs.
IIRC, the default action or suggested setting on Shark codecs is to disable Media Foundation which will mess up your LiveTV playback on WMC.
Foxbat121 is offline
post #6 of 9 Old 01-29-2013, 09:53 AM - Thread Starter
I'll try uninstalling them and see if that fixes the problems. System is 64bit.
I had installed them awhile ago but we've moved since and are planning to move again shortly so I didn't bother setting the AVR up. Will post later tonight with an update.
post #7 of 9 Old 01-29-2013, 02:03 PM - Thread Starter
Uninstalling sharks codecs fixed livetv but broke .mkv playback. Thoughts?
post #8 of 9 Old 01-29-2013, 02:46 PM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
I just released new versions of my codecs that when choosing to use the SUGGESTED settings,
It will ask you if you use LiveTV and if you answer YES, it will not disable Media Foundation.
Current releases at the time of this post are 398 for the Windows 7 release, and version 141 for Windows 8 users.
I release directly to MajorGeeks - every other fileserver gets the distributed installer from MajorGeeks.
Shark007 is offline
post #9 of 9 Old 01-30-2013, 10:08 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Thanks ...
Mfusick is offline
Reply Home Theater Computers
