H.265/HEVC finalized - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 01-30-2013, 01:52 PM - Thread Starter
Tiddles88's Avatar
Liked: 24
H.264's replacement is here, although it will be a long time before its in use looks like - one H.265 decoder at CES was a quad core just to decode HEVC. Anyhoo, here:
http://www.extremetech.com/extreme/147000-h-265-standard-finalized-could-finally-replace-mpeg-2-and-usher-in-uhdtv
Hopefully MPEG 2 will now die out.
Interesting, no?
Tiddles88 is offline
post #2 of 33 Old 01-30-2013, 02:10 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So my i3-550 won't handle it? What's so wrong with h.264 and MPEG2 anyhow? I need to spend more $$ to handle this format?
I am wondering if the CableCo's really want to do that for STB's.. Oh, they'll just pass it on so they don't care do they.
Sammy2 is offline
post #3 of 33 Old 01-30-2013, 02:11 PM
rcrach's Avatar
Interesting, no?
MPEG 2 can't die out very rapidly. It's the DVD standard and the ATSC broadcast standard. All the existing equipment would have to change. It would have a nice impact on streaming however.
rcrach is offline
post #4 of 33 Old 01-30-2013, 02:14 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Old standards die hard, just look at all those "professional" laptops that still include vga ports because they use old projection equipment with vga ports smile.gif
Dark_Slayer is offline
post #5 of 33 Old 01-30-2013, 02:30 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
Simple - taking up less space with a higher bandwidth data stream. UHD/4K, high frame rate, full frame 3D, bluray streaming, more HD channels, more interactive commercials, etc etc etc.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #6 of 33 Old 01-30-2013, 02:52 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I know. I just hate having to spend more money to upgrade my stuff, whether it be "my stuff" or other's stuff from the CableCo because they aren't going to absorb it. What I have works fine and is paid for.
Fortunately there will be a bit of time to accommodate this and hopefully it can be done with a GPU upgrade and not a whole system upgrade.
Sammy2 is offline
post #7 of 33 Old 01-30-2013, 02:58 PM - Thread Starter
Tiddles88's Avatar
Liked: 24
I'd say a GPU upgrade will do it, but H.265 is way better for streaming that MPEG-2 and H.264. I hope it will die out in the broadcast space, at least.
post #8 of 33 Old 01-30-2013, 03:11 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I wonder if the GT-430 I have already will deal with it.
Sammy2 is offline
post #9 of 33 Old 01-30-2013, 03:35 PM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 36
It will not. That is just wishful thinking.
Copyright is not property, it is merely a temporary loan from the public domain.
JerryW is offline
post #10 of 33 Old 01-30-2013, 03:55 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay maybe that is an opinion from the dictator or do you have some more information that supports that opinion. tongue.gif
Sammy2 is offline
post #11 of 33 Old 01-30-2013, 04:07 PM
Quoted: 655 Post(s)
Liked: 434
No, it has to be pointy
post #12 of 33 Old 01-31-2013, 06:44 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Lol
Mfusick is offline
post #13 of 33 Old 01-31-2013, 09:09 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Does anybody know for a fact if an nVidia GT430 is powerfull enough for decoding of h.265?
I searched but could not find this.
Sammy2 is offline
post #14 of 33 Old 01-31-2013, 09:18 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
Wouldn't the GPU chipset have to be built with support for h.265 in mind? Or am I as wrong as can be?
staknhalo is offline
post #15 of 33 Old 01-31-2013, 09:27 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Probably for h/w decoding but maybe f/w can make the h/w do it.
Sammy2 is offline
post #16 of 33 Old 01-31-2013, 09:46 AM
Quoted: 648 Post(s)
Liked: 426
h264 was standardized like 10 years ago and it didn't really become mainstream until 2008 or 2009 (I guess that's debatable - ask the "encoding scene"). I know Pure View for Nvidia cards didn't enable hardware acceleration until a year or two after it was adopted as the next standard.
post #17 of 33 Old 01-31-2013, 10:07 AM
GreenEyez's Avatar
Yes and no. There are 2 ways of getting hardware decoding out of modern GPUs
First method is using the built in video processing unit in the GPU (what Nvidia calls PureVideo for example), which is a very limited chip, made specifically to decode certain codecs (h.264,VC-1,MPEG2) and that`s about it. You can probably forget about that route.
Second one is accessing the power of a modern GPUs shaders, via an API like CUDA (what Nev uses for his LAV Decoders) or OpenCL etc to code a decoder for h.265. This is a far more flexible solution in terms of computing power and flexibility of those shaders. Depending on the floating point and integer power needed to decode h.265 , it`s possibile that the GT430 may or may not have the power to do it. Until the world (developers who are involved in writing decoder/libraries for such applications) see some specs and whitepapers for h.264, nobody knows, only the developers who were involved in creating the standard.
GreenEyez is offline
post #18 of 33 Old 01-31-2013, 11:01 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That was as good an answer as can be expected at this time. Until LAV or another decoder is re-written to decode h.265 we will not know what chip will be the minimum chip that is able to decode it fast enough to avoid dropped frames.
Sammy2 is offline
post #19 of 33 Old 01-31-2013, 01:22 PM - Thread Starter
Tiddles88's Avatar
Liked: 24
The really depressing part is that it will take forever for HEVC to get to the current state of H.264. As soon as your introduce change a lot people just flip out.
post #20 of 33 Old 01-31-2013, 02:04 PM
Quoted: 648 Post(s)
Liked: 426
I was still using xvid until some time in 2010 or 2011
post #21 of 33 Old 01-31-2013, 02:31 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
True.
Sammy2 is offline
post #22 of 33 Old 02-01-2013, 01:17 AM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 36
You are correct. It should be self-evident that the card does not contain an h265 decoder - the GPU was designed circa 2009, went on sale in 2010 and h265 was just standardized years later. It is going to be at least one more generation before a regular nvidia GPU has an h265 hardware decoder.
As for a shader or OpenCL based decoder, that ain't going to happen either. The GT430 has bottom of the barrel math performance, generally struggling to even match the performance of some of the lower-end cards of the previous generation. I couldn't find a solid reference, but h265 is expected to be significantly more math intensive to decode than h264 is.
Plus, nobody has an h264 decoder native to either OpenCL or CUDA (ok CORE has one that is part CUDA, but it ain't open source). Greeneyez was incorrect when he stated that the LAV filter uses CUDA. What the LAV filter uses is CUVID which is Nvidia's way of exposing the card's own h264 hardware decoder through CUDA. Under the hood, it is exactly the same part of the GPU that decodes video via DXVA - LAV does not contain an h264 decoder itself, it only knows how to use the hardware decoders.
JerryW is offline
post #23 of 33 Old 02-01-2013, 05:24 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Now that is better. From further reading and a PM to renethx I now know a bit more about video cards. Basically no video cards sold today will decode h.265 and the only solution for older cards is software decoding in the CPU. It is a good thing this will take a while and will probably be when I upgrade my video card.
Sammy2 is offline
post #24 of 33 Old 02-01-2013, 07:07 AM
vladd's Avatar
Liked: 39
Also, the first generation of cards with H.265 support will probably not support MVC decoding as that extention to the spec is not expected until 2014.
vladd is offline
post #25 of 33 Old 02-01-2013, 08:03 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So I have forever in computer terms. I'm not compelled to upgrade my video card for jinc in madVR but will do it when h.265 is prevelent.
Sammy2 is offline
post #26 of 33 Old 02-01-2013, 11:59 AM
vladd's Avatar
Liked: 39
And a day.
vladd is offline
post #27 of 33 Old 02-01-2013, 12:00 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
LOL!
Sammy2 is offline
post #28 of 33 Old 02-10-2013, 09:22 AM
img eL's Avatar
H.265/HEVC will be implemented way more faster than H.264
img eL is offline
post #29 of 33 Old 02-10-2013, 09:25 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
From what source to you garner this?
Sammy2 is offline
post #30 of 33 Old 02-10-2013, 09:55 AM
img eL's Avatar
H.265 have been in the works for years, software & hardware companies have been testing h.265 for years as well, many have working solutions continually improving
http://www.researchandmarkets.com/research/82svx6/hevc_decoding_in
http://www.marketwatch.com/story/docomo-to-license-hevc-decoding-software-2013-02-04
There will be a announcement from Sony later this month
img eL is offline
Reply Home Theater Computers
