Hi10P - How to encode? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-30-2013, 07:05 PM - Thread Starter
ser_renely's Avatar
Sort of a stupid question and I thought I would find an easy answer with my friend Google. Alas, no joy.
How do I rip a disc to Hi10P? What is a good program to do this in, etc...?
Ser
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
ser_renely is offline
post #2 of 6 Old 01-30-2013, 08:21 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Ser
First you don't 'rip a disc' to anything but its original format. 'Ripping' is copying it to another disk (your Hard Drive) pure and simple. What you use to accomplish this depends entirely on the source. If it's encrypted (most commercial or pressed disks are) you'll need to decrypt it. DVDFab, AnyDVD and MakeMKV are three popular decrypters. If it's a burned disk just copy it by drag and drop or whatever your favorite disc copying method is.
Once you've ripped the disk you can use the files on the hard drive to encode it to Hi10P, perhaps using this guide I found using Google: http://animestash.info/forum/index.php?topic=25121.0
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #3 of 6 Old 01-30-2013, 08:44 PM - Thread Starter
ser_renely's Avatar
Thanks smile.gif I will give it a go
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #4 of 6 Old 01-30-2013, 10:14 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Basically you just need to replace x264 (8 bit) by x264 (10 bit) in any GUI of x264. That's it. MeGUI is one of them. BluRip is an all-in-one ripping/x-264 encoding program (you can do ripping and encoding in one process). Ripbot264 (another x264 GUI) includes both x264 (8 bit) and x264 (10 bit) and you can select either from GUI.
renethx is offline
post #5 of 6 Old 02-01-2013, 04:27 AM - Thread Starter
ser_renely's Avatar
Thanks. I should have looked over at Doom9, totally slipped my mind
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #6 of 6 Old 02-13-2013, 07:03 PM - Thread Starter
ser_renely's Avatar
mgui worked well. Thanks.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
Reply Home Theater Computers
