XBOX360 Extender - mkv performance subpar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-31-2013, 08:11 AM - Thread Starter
Digital Fool's Avatar
I just finished getting the XBOX360 configured for a 'cheap' extender solution. It's hard wired into the network, but I'm finding that any mkv greater than ~10GB is essentially unplayable.
I'm not overly concerned with my movie library as I'll continue to watch movies off my HTPC, but I was just wondering if this is a limitation of the XBOX or my HTPC? When I'm monitoring the HTPC when the XBOX is choking on playback, NIC utilization is less than 1% (gigabit) and the CPU is less than 10%. I encode all of my Blu-rays the same way - just depends on the film as each varies in final output size.
Digital Fool is offline
post #2 of 7 Old 01-31-2013, 08:16 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
The max bitrate is very low for 360/h264/mkv
Depending on how you have things set up the HTPC might be trying to transcode on the fly.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 7 Old 01-31-2013, 08:22 AM - Thread Starter
With media browser, there is an option for Transcode 360 - is that something that needs to be enabled in this case?
post #4 of 7 Old 01-31-2013, 08:48 AM
Quoted: 648 Post(s)
Liked: 426
thats an old and out of development program. you might have luck setting it up to make you happy, but thats not what I was talking about.
Windows Media Connect is a part of Windows that will attempt to convert the mkv into something playable. It is not configurable at all. You will know if it's trying to help by looking at CPU usage during mkv playback on your 360 - if its at 100% its active.
post #5 of 7 Old 01-31-2013, 09:11 AM - Thread Starter
Figured - didn't seem much out there on it recently
Like I said, didn't see much activity at all on the HTPC during mkv playback. I'm not overly concerned, just was curious if anyone in the community does something similar.
post #6 of 7 Old 01-31-2013, 09:16 AM
tgrinch's Avatar
Quoted: 23 Post(s)
My xbox will play between 10-20Mbps blurays pretty well... the higher you go bit-rate wise, the more hit/miss it is. Make sure you have flow-control enabled both on your NIC and on your switch (having a good, dedicated switch will do wonders here...). I have had the occasional lower bit-rate not play well at all as well, so YMMV.
tgrinch is offline
post #7 of 7 Old 01-31-2013, 10:04 AM - Thread Starter
I'll give that a try -
Reply Home Theater Computers
