Media Browser 3 is coming!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
Old 02-05-2013, 02:51 PM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
So if you are on the RecordedTV screen, what happens when you push back on the remote? Do you end up at the Start Screen or the main WMC screen?
Carty Custom Builders, LLC
ncarty97 is offline
Old 02-05-2013, 04:28 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Originally Posted by xzener View Post
Correction... DVD ISOs already work with MB3s embedded player (VLC). It does not work with Bluray. But we are working that. cool.gif
You are using VLC and extracting HD Audio to bitstream to AVR's that can decode it?
Sammy2 is offline
Old 02-05-2013, 09:31 PM - Thread Starter
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
I don't follow... The Bluray ISO does not work with VLC. It plays a Bluray folder rip just fine, but the audio it sends to the (HD audio capable) AVR is not HD audio. We are working on an embedded ISO mounter for Bluray ISO... And VLC is actively engaged on HD audio capabilities. If this doesn't happen by launch, we hope to have a work around (similar to XBMC).
Xzener
xzener is offline
Old 02-06-2013, 06:27 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That is the answer to the question I was asking.
Good to hear that VLC is working on HD Audio as I might switch that to my external player when it does or use MB3 with the internal work around.
Sammy2 is offline
Old 02-06-2013, 06:58 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
MB3 (as of right now) is using a built in ISO mounting method... It is seamless (for DVDs ATM). No more Daemon Tools or Virtual Clone Drive required. smile.gif
That's HOT !!!
Mfusick is offline
Old 02-06-2013, 08:18 AM
jong1's Avatar
Quoted: 136 Post(s)
Liked: 106
What do you mean by embeedded mounter? Does the iso still appear as a drive. I.e. will AnyDVD still be able to do its stuff on protected isos?
jong1 is offline
Old 02-06-2013, 08:31 AM - Thread Starter
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Let me clarify... We are using a program (where code will be written to enable this) to support ISO without the need for external software... at least this is our goal. We will still have the option to use Daemon Tool and Virtual Clone Drive (AnyDVD will be able to do its thing) for ISO so no worries there. You have brought up a good point, I will ask the Devs about our new method, and verify AnyDVD can do its thing.
Xzener
xzener is offline
Old 02-06-2013, 09:46 AM
jhoff80's Avatar
Quoted: 380 Post(s)
Liked: 334
It goes back to the main WMC screen. I just have remapped the "Menu" button to bring me back to start. Probably getting off topic for this thread though.
XBL/Steam: JHoff80
jhoff80 is offline
Old 02-06-2013, 12:00 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
So what's the culmative total time table on all this stuff ?
Mfusick is offline
Old 02-06-2013, 01:21 PM
mcturkey's Avatar
Liked: 43
From their forum thread on it, March for private beta, April for general availability.
mcturkey is offline
Old 02-06-2013, 06:20 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I am not familiar with VLC at all, so I can't say for sure that I'd prefer MPC-HC. If they are able to get HD audio working with VLC and if the video quality is good, then it seems like this would be a fantastic setup. As it stands now, I can't complain about the way my MKV's look or sound with MPC-HC and LAV and MadVR, but the thought of an integrated player that can match that combo is intriguing.
hogues is offline
Old 02-06-2013, 09:48 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 496
I'm a little disappointed. I've never been impressed with VLC's video output, and the lack of HD audio makes it even less useful. The rest looks nice though, and if integration of MPC-HC and TMT5 for 3D playback is easy to setup I'll see how it compares to XBMC.7
Looky here!
robnix is online now
Old 02-07-2013, 11:57 AM
JMGNYC's Avatar
VLC, assuming the add refresh rate changing and HD audio bitstreaming will probably be as good as the WMC internal player, XBMC, Plex etc.
It could conceivably be so close to MPC-HC/madVR/LAV for 1080p and possibly even 720p as to be of little practical difference. However, I cannot imagine VLC coming close the to upscaling abilities of MPC-HC/madVR/LAV for SD 480p video. If you don't have a lot of that or don't mind the quality then it sounds like VLC will be fine.
I'm still not sure what the benefits would be of a so called embedded player (it is still VLC after all) as opposed to a so called external player. I'm sure there are some but I just can't imagine what they are at the moment.
JMGNYC is offline
Old 02-07-2013, 01:52 PM
FantaXP7's Avatar
Quoted: 44 Post(s)
Liked: 38
Better format capabilities than the internal WMC for starters. Also they can make overlays with VLC similar to what different themes of XBMC can do.
It will be much better than WMC's internal player. I am thinking it will be comparable to XBMC's internal player which isn't half bad.
FantaXP7 is offline
Old 02-07-2013, 02:22 PM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
+1 No HD Audio is just silly
mark_anderson_u is offline
Old 02-07-2013, 03:12 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I agree. A few years ago, it wouldn't have been that big a deal, but these days it's a must in my opinion. The good thing is that it sounds like VLC is working on it and there is a contingency plan from the devs if that doesn't pan out. That just leaves video quality.
hogues is offline
Old 02-07-2013, 04:39 PM
JMGNYC's Avatar
I wasn't so much thinking of the internal WMC player could have done with it, rather MPC-HC. But, yeah I can see overlays and such would be nice. But, personally I'd rather the picture quality of a player than can support madVR over something like that.
Now, if it can support chapter selection, subtitle selection, and audio selection with an overlay menu that'd be worth thinking about. With MPC-HC, you can do chapter skip, next/previous subtitle or audio but that's it really.
JMGNYC is offline
Old 02-07-2013, 05:28 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 496
That one complaint aside, I'm still very interested in trying this out, I've made several purchases from the Mediabrowser folks and would like to be able to return to my investment.
Looky here!
Old 02-07-2013, 07:01 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I couldn't agree more. I'm very excited to see what this brings.
hogues is offline
Old 02-07-2013, 09:36 PM
JMGNYC's Avatar
Since I've read that MB3 will still support MPC-HC as an external player I'm also very excited to see it too.
JMGNYC is offline
Old 02-08-2013, 07:30 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
XZENER
XZENER,
I think your icons are pretty cool. Any plans to do more ? I am using many of them for collections but some collections have new movies in them. Any updates planned?
Mfusick is offline
Old 02-08-2013, 12:50 PM - Thread Starter
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Thanks Mfusick,
My plate is overflowing ATM. Work, school and MB3... I really want to get back into it, who knows... Maybe I will build a Xzenersoft website??? I am in an HTML5 class in school... Stay tuned.
Xzener
xzener is offline
Old 02-08-2013, 02:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
You'd probably make some $$. I'd easily donate $5 bucks ... as would many here for access to good stuff.
Anything under $10 US is usually not a big factor for most serious enthusiasts.
You won't get rich.. but you can at least offset your time spent on it.
Mfusick is offline
Old 02-08-2013, 03:05 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 496
Agreed - Two things I like about MB more than XBMC:
  1. The Addon browser
  2. The MB business model is that addons are inexpensive and only needed for eye candy.
I'd gladly pay $5.00 for those icons if they were part of the addon tool and were autoinstalled and updated.
Looky here!
Old 02-08-2013, 03:47 PM
Dark_Slayer's Avatar
Quoted: 659 Post(s)
Liked: 434
I don't entirely follow. You feel like the addons are inexpensive compared to XBMC? Rom Collection Browser, Music Managers, Artist and Album artwork downloaders, impressive skins are all free in XBMC. MB plugs you $5 or so a piece
Dark_Slayer is offline
Old 02-08-2013, 04:46 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I think he is saying the MB method for installing and obtaining is superior to the XBMC method and that paying a small fee for something like Coverart is not a big deal if it's turn key, easy and looks great.
MB plugins are superior to XBMC in that they are more simple to install and configure- all available in a single area and quickly downloaded and installed. Sure the paying for them sucks... but the entire process is easier.
The costs might be justified for XMBC. I'd pay a few bucks for it to have an easier add on interface. Just click what you want to add- like in mediabrowser.
Mfusick is offline
Old 02-08-2013, 04:58 PM
Quoted: 659 Post(s)
Liked: 434
more simple to install - all available in a single area and quickly downloaded and installed
Well, I like mediabrowser and I like options, but . . .
There's a lot accessible from the main repo that comes packaged with the install
It's a lot easier to keep them ALL in one place when there are less than 50 total rolleyes.gif
Old 02-08-2013, 11:05 PM - Thread Starter
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Plugins are about to get even easier to install. Plus, depending on the developer, previously paid for plugins will be honored with your MB2 supporter key. Previous supporters will find their favorite plugins ported over and available for immediate install. Providing you have cut and pasted your MB2 supporter key in the appropriate spot in the MB3 dashboard.
Xzener
xzener is offline
Old 02-08-2013, 11:09 PM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
amarshonarbangla is offline
Old 02-08-2013, 11:38 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 496
Exactly.
Been there with both. This is MUCH easier:
You can be as snarky and eye rolling as you want, but getting to and navigating the addons menu in XBMC is not intuitive, especially once you leave the Confluence theme and use other themes that change the menu system.
How about stupid things like adding repos via zip which you have to do for AEON MQ4, where HOME in XMBC means the XBMC home folder not the USER home folder, so to install NEW repo I have to navigate through C:\Users\username\location of downloaded zip etc... and if you have 2 zips to install, XBMC doesn't remember last location, so I have to do it again.
XBMC does a lot of things right, but a consistent and always easy to use interface sure isn't one of them.
Looky here!
Mediabrowser , Mediabrowser 3
