Question about VLC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-31-2013, 09:49 PM - Thread Starter
Barbarian887's Avatar
How do I go about setting VLC to display the highest resolution on my DVD but on a 4:3 screen and cropped, for example the highest resolution available centered and cropped to 1024x768 so there's no loss in quality or scaling
thanks
Barbarian887 is offline
post #2 of 6 Old 02-01-2013, 08:22 AM
sitlet's Avatar
Quoted: 16 Post(s)
Not sure exactly what you are asking. A dvd only has one resolution, and that's what VLC will play. The video card does the scaling to whatever your output resolution is. And it won't display the content as 4x3 unless the dvd was authored in 4x3.
sitlet is online now
post #3 of 6 Old 02-01-2013, 12:06 PM - Thread Starter
Like imagine opening an image in an image viewer, zooming in until the resolution is dot-fordot, notice how it maintains the original image, cropping any excess off of the sides
that's what i want in my video, so it isn't being scaled.
post #4 of 6 Old 02-01-2013, 06:34 PM
DanPackMan's Avatar
Quoted: 299 Post(s)
Liked: 599
There are some command line options in VLC for cropping. I don't think there are any ways to do it with the GUI. Check the VLC site for those command options.
DanPackMan is offline
post #5 of 6 Old 02-01-2013, 08:05 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
thanks
If your source is DVD and you don't crop or scale it it will be at most a 720X480 image. I doubt that's what you want. VLC is actually pretty flexible when it comes to scaling and zooming and cropping. The settings are just a right click away:
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 6 Old 02-02-2013, 05:16 AM - Thread Starter
oh i hadn't seen those options yet, that's pretty much what i was after ,thanks
Reply Home Theater Computers
