Looking for a simple media trim/cut tool for AVC/DTS (MKV container) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-01-2013, 09:15 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I know years ago, there wasn't any way to directly cut/trim media files that contained DTS audio.  I just checked today thinking by now there should be several tools that do this for free or shareware products.  To my surprise, I STILL can find anything that could does this.  Even VideoRedo TV Suite seems to have purposefully limited this capability until they get DTS licensing sorted out.
Can someone offer any suggestions that dont introduce several extra unnecessary steps with multiple tools or time-consuming re-encoding tools?  I just need something simple that does the trim job in one quick step.
MKANET is online now
post #2 of 12 Old 02-02-2013, 05:01 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #3 of 12 Old 02-02-2013, 11:47 AM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Thanks for replying renethx.  Last I checked, MKVmerge GUI isn't a media file trimming/cutting tool.  Im just looking for a simple cutting tool that can easily trim/cut parts off several media files (similar to how Videoredo works).  The only way I know how to do it requires multiple steps and multiple tools (MKVmerge being one of them); which isn't feasible for trimming several mkvs.
I'm pretty sure there still isn't any tool that can do this; but just wanted to be sure.
post #4 of 12 Old 02-02-2013, 01:30 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
I used TsMuxser for trim and cut before. I have no problem with even the DTS-HD track.
MKANET likes this.
Foxbat121 is offline
post #5 of 12 Old 02-02-2013, 01:47 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Oh ... i didnt think about that!  I forgot that tsmuxer can cut too.  That might be my only option if I want to do it in just one tool.
post #6 of 12 Old 02-02-2013, 02:26 PM
jim2100's Avatar
Liked: 34
What exactly do you mean by "trimming" and "cutting" and what is the difference?
MKVmerge can arbitrarily split and join MKV files, so you can certainly take any MKV file and cut out bits that you don't want. But if you need multiple segments cut out, it is a tedious process since MKVmerge can only make one split per run.
jim2100 is offline
post #7 of 12 Old 02-02-2013, 02:47 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
See VideoRedo for an example.
post #8 of 12 Old 02-02-2013, 02:54 PM
jim2100's Avatar
Liked: 34
See dictionary for definition of "exactly".
jim2100 is offline
post #9 of 12 Old 02-02-2013, 02:54 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
AVIDeMux may be able to as it does stream copy. Limited to 'i' frames though.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #10 of 12 Old 02-02-2013, 02:58 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I just tried the latest version of TsMuxer.  How do you trim or cut parts of the video without seeing what your cutting?  The version I use doesnt have a preview display.  I wonder if there's another tool that has the ability to see what youre actually cutting.
post #11 of 12 Old 02-02-2013, 03:54 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
For those of you interested in doing the same thing as me... simple cutting tool for mkvs with DTS, it looks like SolveigMM Video Splitter 3 is about as good as it gets.  It does exactly what I wanted it to; and, it doesnt have the bloat that encoding/editing software offers.  Plus, it lets you keep the original container; such as MKV.  Basically.. just like videoredo without the DTS limit.
The only issue I have right out of the box is it seems to be kind of slow when FF/REW through the video to select start/stop points.
post #12 of 12 Old 02-04-2013, 09:55 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
I use my video player to locate the time stamp and put it into the TsMuxer. Not the most convenient way but get the job done with the tools I have.
Reply Home Theater Computers
