Should I replace my Mobo with something new or the same piece I have? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-02-2013, 12:01 PM - Thread Starter
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
I have to order a new Mobo, because of a liquid spill that shorted out the current unit (Asrock E350M1 AMD E-350 APU).
I had no issues with the motherboard, so I was just going to order another one, but then I started thinking. Can I do the job w/o a decrease in performance for less than $100?
I have a basic build (Win 8 Pro, Seagate 2TB 5900 RPM HD, 2 2GB DDR, LG Blu Ray Drive). The HTPC is mainly used for viewing Blu Ray discs/.mkv files thru XBMC. I do not use it for DVR or gaming.
If you were in my shoes, what mobo would you put back in your HTPC?
Thank you,
slosvt is offline
post #2 of 4 Old 02-02-2013, 12:29 PM
Tiddles88's Avatar
Liked: 24
Intel G1610 + Asrock B75M-GL for a buck or two over 100, assuming you have an mATX case. Vastly faster than an 350 APU.
Tiddles88 is offline
post #3 of 4 Old 02-02-2013, 01:25 PM - Thread Starter
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
I have the following case:
SILVERSTONE Black Aluminum skin reinforced plastic front panel, 0.8mm SECC body MILO Series ML03B Micro ATX Media Center / HTPC Case
Is the I3 worth the extra cost of the basic Intel CPU?
slosvt is offline
post #4 of 4 Old 02-06-2013, 04:52 PM - Thread Starter
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
Tiddles,
How much difference would I see in using the Intel G620 + Intel boxdh67blb3 vs. your suggestion. I looked at the I3 but that would run more than I wanted to spend at this time.
Thank you,
slosvt is offline
Reply Home Theater Computers
