Inteset - AVS Forum | Home Theater Discussions And Reviews
Old 02-03-2013, 05:09 PM - Thread Starter
rcrach's Avatar
If you're looking for a quality full size case, this looks like an incredible deal for the money.
http://shop.inteset.com/Products/7-heatsink-aluminum-case.aspx
rcrach is offline
Old 02-03-2013, 05:36 PM
macks's Avatar
Liked: 31
LGA 775 only. Trash?
macks is offline
Old 02-03-2013, 05:54 PM
Tiddles88's Avatar
Liked: 24
Malware. Came up as blocked here. Avoid.
Tiddles88 is offline
Old 02-03-2013, 06:49 PM
vladd's Avatar
Liked: 39
Most likely a false positive. Inteset is pretty well known here. They are about the only suppliers of of internal CIR receivers for Intel/ASRock motherboards.
vladd is offline
Old 02-03-2013, 07:00 PM
gazebo's Avatar
Quoted: 14 Post(s)
Maybe it's some surplus case Inteset bought in bulk and rebadged with their name?
Check out the HD DVD logo on the DVD door. They must have bought the cases back in 2008 before the HD DVD camp gave up the fight. LOL.
gazebo is offline
Old 02-03-2013, 07:04 PM
t-c
t-c's Avatar
I think they are old cases fom Atech-Fabrication.
t-c is offline
Old 02-03-2013, 07:18 PM - Thread Starter
rcrach's Avatar
Malware? LGA775 only, Trash? Let's all pile on. It may be an older case but let's be honest, for 190 dollars that's a hell of an enclosure.
rcrach is offline
Old 02-03-2013, 07:47 PM
vladd's Avatar
Liked: 39
I wish I had some "trash" from Atech Fabrication.
vladd is offline
Old 02-04-2013, 12:03 PM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
The "malware" hit is likely a wannabe AV hackjob signature flagging on the tiff image or similar, run into this at work a lot. (the 'antivirus' industry blows, nearly worthless on new malware or real threats, you can dial it up to paranoid then it starts flagging operating system files)
LGA775 dimensions etc are very close to 115x (which includes upcoming haswell) so the mounting can probably be adapted to it without too much trouble.
It would be nicer if the front plate didn't have such prominent logos, but overall that case is very high quality for the price.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
