Windows Metro- Hulu/Netflix Remote commands - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-05-2013, 02:40 PM - Thread Starter
cazten's Avatar
Has anyone compiled a list of possible Netflix/Hulu remote commands for the Metro UI?
I've gotten some functionality to work, like play/pause, backing out of menus, and some amount of Navigation in netflix. But HULU is a bust. and navigation in netflix is pretty finicky and cant get past the main categories (aka I cant actually enter the categories just see the popular hits)
- Trying to get it all remote able without using a trackpad app.
cazten is offline
post #2 of 4 Old 02-05-2013, 02:45 PM
macks's Avatar
Liked: 31
I wouldn't be surprised if it never works correctly.
macks is offline
post #3 of 4 Old 02-05-2013, 06:19 PM - Thread Starter
cazten's Avatar
That would be really lame. I run on a 100" screen so I need the appliance based versions that will run HD and "super" HD. Its been workable using an ipad with a remote touchscreen app. Maybe Ill look into buying a dedicated trackpad or something. Just works so much nicer to press buttons with the Girlfriend and visitors vs mouse cursor
cazten is offline
post #4 of 4 Old 02-05-2013, 07:50 PM
spivonious's Avatar
I've had lots of problems with Windows 8 and the remote. I can't skip forward by 30 seconds anymore in recorded TV, PowerDVD 11 doesn't load within Media Center, and Netflix doesn't like anything but arrow keys.
spivonious is offline
Reply Home Theater Computers
