Streaming 1080 over WiFi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-05-2013, 08:43 PM - Thread Starter
hollatbk's Avatar
Can someone school me on this?
I have a HTPC with all my media located on it. I'm running Plex on the HTPC. When I try to play 1080 movies on my laptop through Plex Media Center the video buffers every few seconds.
hollatbk is offline
post #2 of 13 Old 02-06-2013, 12:40 PM
sitlet's Avatar
It would help if you gave us details about your wifi setup, and what kind of media you are streaming (resolution, bitrate, etc). But basically, you wont be able to stream most 1080 material over a 54g network, it's too slow.
sitlet is offline
post #3 of 13 Old 02-06-2013, 12:58 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Hardline it. Wireless is simply never going to work 100% of the time for 1080p (unless it's super compressed 1080p I suppose). You could too Plex Media Center to transcode it to a lower quality, which would help.
lockdown571 is online now
post #4 of 13 Old 02-06-2013, 01:10 PM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Never? What about the new 802.11ac routers once that equipment matures?
Karyk is offline
post #5 of 13 Old 02-06-2013, 01:51 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Never 100% of the time is what lockdown571 said.
Sammy2 is offline
post #6 of 13 Old 02-06-2013, 02:09 PM
Quoted: 36 Post(s)
Liked: 87
Theoretically, yes. Practically, no. Wireless is subject to interference from a lot of sources, and you can never expect 100% reliability. It doesn't matter how fast the protocol is.
post #7 of 13 Old 02-06-2013, 02:55 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
In order to overcome these issues via wireless, you need a lot of buffer memory and have to tolerate a lot of buffering before actual payback.
Sammy2 is offline
post #8 of 13 Old 02-06-2013, 04:52 PM
sycochkn's Avatar
I am successfuly playing Bluray ISOs over my network with a Netgear R6300 and a Netgear A6200 (80211.ac) with file sharing. I am using Virtual Clone Drive and PowerDVD10 ultra or XBMC. I just tried and eperiment I played two different movies at the same time over the wireless network one is stored on one computer and one is stored on the other. They both play just fine.
sycochkn is offline
post #9 of 13 Old 02-06-2013, 08:13 PM - Thread Starter
hollatbk's Avatar
The HTPC:
ios
CPU - Sandy Bridge LGA1155 (3D) Intel i3-2100
MoBo - GIGABYTE GA-Z68MA
RAM - G.Skill 2x2GB DDR3
HDD - WD Green 2TB
The Laptop:
CPU - Intel® Core i7-3632QM
RAM - 8GB DDR3
Router is just the standard Cable Modem with a built in wireless router from Verizon Fios. I do know its a newer version capable of 300 Mbps over the wireless. (Model: Actiontec mi424wr)
Here's the thing. I play all my movies through my HTPC on my 1080 HDTV, or stream them to my roku located in my bedroom that is connected to a 720 HDTV via Plex. I just got a new laptop that is 1080p and for ****s and giggles I was trying to stream Blu-Rays from my HTPC to the laptop via Plex so I could see how they looked. I know I could always just directly hard wire my laptop to the router but that's beside the point. From what I'm gathering streaming 1080p over wireless isn't practical.
hollatbk is offline
post #10 of 13 Old 02-06-2013, 08:22 PM
jeffkro's Avatar
I finally got my wireless N running 1080p with almost no stutter, you just to have really really good signal strength. I'm just using windows network sharing, no plex or anything.
jeffkro is offline
post #11 of 13 Old 02-06-2013, 09:15 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
Its not about the quantity (speed, strength of signal, etc) its about the quality (lack of interference and dropped packets).
Our baby monitor is a wireless internet terrorist.
Sammy2 likes this.
assassin is online now
post #12 of 13 Old 02-06-2013, 09:18 PM
vladd's Avatar
Liked: 39
Ain't that the truth!!
vladd is offline
post #13 of 13 Old 02-08-2013, 06:27 AM
ShadoeOSU's Avatar
No kidding. Our monitor operates at 2.4GHz and it completely killed our wireless network. I had to upgrade to a 5GHz router just to get around the interference.
ShadoeOSU is offline
Reply Home Theater Computers
