Soundcard with phamtom center channel via a digital output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2013, 09:26 PM - Thread Starter
Colin's Avatar
Well, the title just about says it all. When playing blueray movies, I want to have a soundcard that will create a phantom center channel and output the signal in the digital domain via either TosLink or Coaxial cable. Any recommendations? Anywhere I should look?
CB
Colin is offline
post #2 of 3 Old 02-11-2013, 09:30 AM - Thread Starter
Colin's Avatar
bump. Any thoughts?
Colin is offline
post #3 of 3 Old 02-11-2013, 10:08 AM
Puwaha's Avatar
Liked: 35
Usually the AVR/audio receiver does this for you. You should be able to tell it to expand a stereo signal to pseudo-5.1.
Puwaha is offline
Reply Home Theater Computers
