replace internal cd/dvd with a blu ray drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-07-2013, 06:01 PM - Thread Starter
kwed's Avatar
I have an HP s5-1400t slimline pc currently being used as my htpc. I have no complaints so far and was thinking about swapping out the cd/dvd for a bluray drive. I was wondering if there are any recommendations out there. And I was also wondering if the eject button on the computer would still work after the switch. Thanks in advance.
kwed is offline
post #2 of 4 Old 02-07-2013, 09:52 PM
sitlet's Avatar
I'm not sure about that specific model, but I have done this with two laptops. There are usually only a few "standard" slim drive types, just make sure you get the correct one.
Although I would recommend a cheaper option: buy an external BD drive, or buy a 5.25 internal drive and an external enclosure.
sitlet is offline
post #3 of 4 Old 02-07-2013, 11:51 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
+1. Also quicker and a lot more reliable.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 4 Old 02-08-2013, 06:18 AM - Thread Starter
kwed's Avatar
ok thanks for the info. I have an external blu ray, but was trying to consolidate into one thing for my wife. Keeps the switching of inputs to zero. Thanks.
kwed is offline
Reply Home Theater Computers
