Would this work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-08-2013, 11:10 AM - Thread Starter
badhaircut's Avatar
I have a set of 2.1 Logitch speakers/ sub. The speakers connect with a 3.5mm jack. My Tvs only means of external audio output is a toslink connector (there is no headphone jack)
I want to be able to control the volume of the speakers using a harmony remote so I'm looking at buying a used external sound card like this http://www.behardware.com/articles/562-1/sound-blaster-digy-4-pro.html
I basically want to scrap the internal car and use the external portion as a sort of receiver.
This external portion can most likely be powered by a usb cable either attached to my tvs usb port or I can buy a usb to 120v adaptor.
If I attach a toslink cable to the soundcards optical input and plug in my speakers, do you think I can get these speakers to work and have volume control? Or will the sound only work through a software based program?
In case you're wondering. I dont have room on my entertainment stand for a receiver nor do I have room for one in my budget. The used soundblaster im looking to buy will only cost me 25 bucks
Thanks in advance
badhaircut is offline
post #2 of 7 Old 02-08-2013, 11:35 AM
ntculenuf's Avatar
this might also work. than you should be able to use the volume control of the tv.
out of TV to convertor with optical cable>plug speaker 3.5 cable into RCA to female 3.5 cable
digital to analog convertor
ntculenuf is offline
post #3 of 7 Old 02-08-2013, 11:39 AM - Thread Starter
badhaircut's Avatar
I tried that with the Fiio adapter. The speakers work fine but the tv remote doesnt adjust volume of the speakers.
post #4 of 7 Old 02-08-2013, 11:44 AM
ntculenuf's Avatar
some tvs don't allow that when using externals guess yours is one of them. for $25 go for it don't see why it wouldn't. the sound blaster has its own remote. not sure about the usb, but going from optical into should work.
post #5 of 7 Old 02-08-2013, 01:09 PM - Thread Starter
badhaircut's Avatar
Yeah thats what I thought at 25 bucks its worth a shot.
post #6 of 7 Old 02-14-2013, 06:18 AM - Thread Starter
badhaircut's Avatar
Just thought I'd update on this. The external soundcard does work amazingly. I even programmed my harmony remote to work with it. The only issue I have is that I cannot control the bass of the sub or fine tune the satelite speakers such as treble etc. But for 25 bucks I am able to use pc speakers with my tv so Im not complaining. There is no need to have the soundcard hooked up to my computer either, works just like a mini receiver smile.gif
post #7 of 7 Old 02-14-2013, 07:53 AM
ntculenuf's Avatar
thats is awesome! One of the best things about this hobby is trying things and seeing what happens
Reply Home Theater Computers
