Building a new HTPC - need advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-10-2013, 06:53 PM - Thread Starter
kgoyal's Avatar
Hi All -
I built my HTPC about 2.5 years ago with the help of this forum. I've received a lot of joy from it, though it is now starting to show its age.
I'm looking to build a new HTPC. Looked through the forums and in need of some recommendations.
Goals:
- Computer will only be for HTPC use, though looking for a fast CPU as I want minimize wait time when encoding video files and I may add a media center extender in the future
- Will look to use the onboard GPU (not purchase a separate one)
- Not looking to overclock
- Need recommendations on memory
- Recommendations for keeping the setup cool. My case does vent well.
- Should be compatible with Ceton InfiniTV 4
I don't build computers often so my knowledge base has a few holes. Thanks all!
kgoyal is offline
post #2 of 10 Old 02-12-2013, 09:55 AM - Thread Starter
kgoyal's Avatar
Shameless bump.
kgoyal is offline
post #3 of 10 Old 02-12-2013, 10:51 AM
jeffkro's Avatar
Originally Posted by kgoyal View Post
Hi All -
Goals:
Core i5 ivy bridge with HD4000 graphics should do the trick, or you could do the video encoding on your desktop.
jeffkro is offline
post #4 of 10 Old 02-12-2013, 07:42 PM - Thread Starter
kgoyal's Avatar
thanks jeffkro...what motherboard would make a good HTPC with that? Looking for HDMI out, optical out, and anything else thats important for and HTPC...
kgoyal is offline
post #5 of 10 Old 02-13-2013, 05:02 AM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
Look for any H77 motherboard.......just need to pick a form factor - ATX, Micro ATX,etc......most will come with the necessary connections to do what you want (i.e. HDMI, toslink, etc)
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #6 of 10 Old 02-13-2013, 06:52 AM - Thread Starter
kgoyal's Avatar
Should have mentioned that I'm looking for a Micro-ATX board. Any recommendations?
The last board I bought was the Intel G45 (despite the warnings on this forum) and it gave me nothing but problems when in sleep mode.
Looking for a stress free board. I plan to only have one hard drive and two sticks of memory.
kgoyal is offline
post #7 of 10 Old 02-13-2013, 07:12 AM
victor M's Avatar
I just recently purchased the Asrock Pro-4m (z77 chipset) Board for my HTPC build. So far it's been working without issue. Has all the Multimedia connections you need. If you purchase your Processor and MB together at Microcenter they give you 50 off the board. I got this one for 49.99 (For the win)
victor M is offline
post #8 of 10 Old 02-13-2013, 08:00 AM
spivonious's Avatar
I'm going to jump into this thread too with a slight hijack. I also have a G45-based HTPC and have found that DXVA is broken in WIndows 8. This makes watching blu-ray discs next to impossible, so I'm looking to upgrade.
I'd prefer to simply add a video card instead of building a whole new system. Have the problems been worked out of the latest ATI cards? I would need a low-profile card.
spivonious is offline
post #9 of 10 Old 02-13-2013, 09:22 AM - Thread Starter
kgoyal's Avatar
Thanks Victor - I'm less price sensitive and more quality focused...would ASRock give me the least amount of problems? Any consensus on the top one or two boards for basic HTPC functionality?
kgoyal is offline
post #10 of 10 Old 02-13-2013, 09:57 AM
macks's Avatar
Liked: 31
I've had no problems with dxva with a 5570 and a 5870 on Windows 8. I've been running Windows 8 since the day after it was released. I experienced issues with Windows 7 but none with 8 on the exact same hardware.
Edit: I had no dxva issues on Win7, other issues arose.
macks is offline
Reply Home Theater Computers
