Inteset and Harmony One - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-11-2013, 10:36 AM - Thread Starter
AnthonyJS02's Avatar
Hello all trying to use my Harmony One to control my Htpc. I have Asrock Z77pro4m board with the inteset Asrock CIR cable. It's activated in the bios, it's in device manager. But i am not getting any feedback. I'm using the Windows Media Center SE device name. Created activity but no luck, tv and reciever go to right place and my Xbox turns on but figured out how to turn that off. But just the Xbox would turn on not both. I haven't had chance to change Xbox setting and try the pc, but figured the remote would send command to both anyways. Spent 5hrs trying to figure out on own but still racking my head on this one. Does that device name not work with Inteset CiR? I haven't tried another one. I've tried just checking to see if any other commands work thinking just powering wasn't work but no response. Any help would be great! Thanks.
AnthonyJS02 is offline
Reply Home Theater Computers
