Best remote desktop software? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 02-11-2013, 03:19 PM - Thread Starter
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
So apparently Windows Live Mesh support is ending Feb. 13th. First of all, does anyone actually know what this means? Will Live Mesh instantly stop working on the 13th?
The is pretty crappy considering Sky Drive simply does not replace all of Live Mesh's features. I use Live Mesh to remote desktop into local and remote computers. What are the alternatives. I tried LogMeIn, but it simply isn't working. I can see the desktop but mouse clicks don't work at all. I also had weird issues just getting my account activated. In the first five minutes of using this I'm already quite disheartened. It's also confusing because I guess I temporarily have Pro features. The dashboard has about a million different features and options, and it's completely overwhelming. I simply want remote desktop and nothing else.
Are there any other options? I can obviously use the built-in Windows remote desktop software for local machines, but how do I access computers outside my network? I manage a WMC machine for my parents, and it's crucial I can fully control it.
lockdown571 is offline
post #2 of 29 Old 02-11-2013, 03:58 PM
bryansj's Avatar
Quoted: 1133 Post(s)
Liked: 560
I just use the built in remote desktop. Your PCs need windows pro or higher. You just have to forward the rdp on your router, typically port 3389. Then use a dynamic DNS service such as dyndns.org.
bryansj is offline
post #3 of 29 Old 02-11-2013, 04:06 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 87
Thanks for the info. Unfortunately not all the computers are Pro. Can a Pro machine access a Windows 7 Home machine?
post #4 of 29 Old 02-11-2013, 04:09 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
I use teamviewer
Andy_Steb is offline
post #5 of 29 Old 02-11-2013, 04:49 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 87
Originally Posted by Andy_Steb View Post
I use teamviewer
Thanks for the recommendation. Logmein eventually started working, so I'm going to try that for now. I'm a bit worried about what's going to happen when my 'Pro' trial runs out. I think the free version has everything I need.
post #6 of 29 Old 02-11-2013, 04:51 PM
bryansj's Avatar
Liked: 560
What is missing is the RDP server. All versions of Windows have the client, but only Pro and above have the server (except XP which has the server in all versions).
There is a hack out there to enable the RDP server on non-pro systems.
http://experts.windows.com/frms/windows_entertainment_and_connected_home/f/114/t/79427.aspx
bryansj is offline
post #7 of 29 Old 02-12-2013, 08:25 AM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Team Viewer = Free
TightVNC = Free
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #8 of 29 Old 02-12-2013, 09:31 AM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
Originally Posted by kevin g. View Post
Team Viewer = Free
TightVNC = Free
+1
amarshonarbangla is offline
post #9 of 29 Old 02-12-2013, 09:34 AM
tgrinch's Avatar
Quoted: 21 Post(s)
I just went through the same thing - I was using Live Mesh to manage my folk's DVR/HTPC remotely and it worked well. I just switched to Teamviewer and seems to work well enough - free, thus far and pretty simple setup. I didn't want to port fwd RDP ports since that opens up security issues over internet.
tgrinch is offline
post #10 of 29 Old 02-14-2013, 01:50 PM
dpn
dpn's Avatar
Teamviewer works fine for me.
DPN
dpn is offline
post #11 of 29 Old 02-14-2013, 02:05 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
I run both remote desktop and VNC. The benefit of VNC is it also works from iOS (and probably android) devices and supports HippoRemote.
mdavej is offline
post #12 of 29 Old 02-14-2013, 02:06 PM
Midwayman's Avatar
Teamviewer works great and is dead simple to get working.
Midwayman is offline
post #13 of 29 Old 04-30-2013, 05:07 AM
bizzybody2g12's Avatar
how to i connect to teamviewer??
bizzybody2g12 is offline
post #14 of 29 Old 04-30-2013, 05:07 AM
post #15 of 29 Old 04-30-2013, 08:22 AM
Quoted: 28 Post(s)
Liked: 43
Download and install it from the Teamviewer website. Each computer will have a unique ID and a randomly changing password (you can set it to a permanent password). Just enter the ID and password of the computer you want to remotely view on the computer you want to view from.
post #16 of 29 Old 04-30-2013, 09:58 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Is there any limitation what you can do with teamviewer versus real remote desktop ??
Mfusick is offline
post #17 of 29 Old 04-30-2013, 10:31 AM
Quoted: 28 Post(s)
Liked: 43
I didn't experience any limitations.
post #18 of 29 Old 04-30-2013, 10:56 AM
bryansj's Avatar
Liked: 560
I'm not sure how Team Viewer deals with drag and drop, copy and paste, and audio. I'd expect the limitations to appear there. I've also never tried Team Viewer with WMC running. That causes VNC to fail.
bryansj is offline
post #19 of 29 Old 04-30-2013, 11:01 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
i use teamviewer also, only thing is that if you have full screen video or xmbc full screen on the machine you are connecting to, that will show blank. i just use the \" key to get out of full screen.
audio plays through fine. copy/paste for text works. there is a file transfer button, but i dont think you can drag it over.
aliaskary77 is offline
post #20 of 29 Old 04-30-2013, 11:06 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Is team viewing a good option to remote over the internet outside my own network and control my parent pc for stuff ?
Mfusick is offline
post #21 of 29 Old 04-30-2013, 11:19 AM
Quoted: 28 Post(s)
Liked: 43
I would prefer TeamViewer over a VNC client for controlling computers outside of your network. Remotely accessing VNC clients requires to open the computer to the internet, which is very dangerous. Teamviewer is a much safer option in that regard.
post #22 of 29 Old 04-30-2013, 11:30 AM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
I do exactly that on a regular basis. (for running utilities, that my parents never seem to run.) It allows safe mode with networking as well..(I had to dump a pesky program that my folks got taken in to installing) Full control...downloads, file transfer, (I was able to add a utility program to my parents PC, from my "downloads" folder...they did have to be there to accept the transfer...I think it is just a one time "yes" for them.) installing programs, etc...
kevin g. is offline
post #23 of 29 Old 04-30-2013, 11:39 AM
bryansj's Avatar
Liked: 560
That is one of the best uses for Team Viewer. Just last week a co-worker had trouble getting his Office 2013's Outlook to send and receive his Gmail. After many many emails trying to troubleshoot it I just had him run the non-installed version of Team Viewer. What he had on his screen was Outlook XP (2001). Office 2013 didn't uninstall the old one and he kept clicking the old shortcut. I fixed his shortcuts and uninstalled the old crap and looked around for anything else to fix. Worked great.
Before that my Crashplan failed to back up to my parents' out of state PC so Team Viewer come to the rescue again.
Now for home use within your own network I just stick with RDP if the clients support it.
bryansj is offline
post #24 of 29 Old 04-30-2013, 12:29 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
thanks !
Mfusick is offline
post #25 of 29 Old 05-02-2013, 05:49 AM
aliasgarbabat's Avatar
In order to remotely access computers outside your network, you have two options: either use hosted services such as logmeinrescue, gosupportnow, GoToMyPC etc. or deploying on premise RHUB remote support appliances.
aliasgarbabat is offline
post #26 of 29 Old 05-02-2013, 06:01 AM
bryansj's Avatar
Liked: 560
Or a simple port forward on the guest's router.
bryansj is offline
post #27 of 29 Old 05-02-2013, 07:46 AM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Or:
3. TeamViewer...
kevin g. is offline
post #28 of 29 Old 05-02-2013, 08:10 AM
bryansj's Avatar
Liked: 560
http://www.amazon.com/gp/product/B0070DOHQS/
This is the exact program that I use to remotely connect to my home computers using my Android phone. Grab it for free today only.
bryansj is offline
post #29 of 29 Old 07-11-2013, 07:01 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
Reply Home Theater Computers
