Best PCIe card for IDE Blu-ray and hd-dvd? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-11-2013, 05:04 PM - Thread Starter
AnthonyB's Avatar
I'll upgrade the player at a later date, I know IDE is old.
Will get a combo drive when I get rid of my tower and get an HTPC case.
AnthonyB is offline
post #2 of 8 Old 02-12-2013, 09:31 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Do they even make IDE controllers with PCIe interfance? I thought they were only PCI.
I actually didn't know they made BluRay drives with IDE, either.
I know that some add-on IDE controllers don't support ODD, and only support HDD, so watch out for those.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #3 of 8 Old 02-12-2013, 04:49 PM - Thread Starter
AnthonyB's Avatar
I am done with the headache. Going to get a couple ide to sata bridges and make sure they have atapi support
AnthonyB is offline
post #4 of 8 Old 02-13-2013, 10:29 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
They never worked for me.
post #5 of 8 Old 02-13-2013, 03:54 PM - Thread Starter
AnthonyB's Avatar
The Rosewill one says it is specifically for CD/DVD so, I'll hope that it is OK.
AnthonyB is offline
post #6 of 8 Old 03-02-2013, 01:06 PM - Thread Starter
AnthonyB's Avatar
OK. Got the Rosewill IDE to SATA Bridge and they don't play well with AHCI. So, I am dumping the entire idea and just bought a SATA combo drive for HD-DVD and Blu-ray. I tried both of the options (pci card and adapter) and the decision to replace my $600 burner did not come lightly.
AnthonyB is offline
post #7 of 8 Old 03-05-2013, 09:08 AM
jyzz's Avatar
curious which model of IDE drive did you have? I was only aware of the LG BD/HDDVD combo and writer back in 2006/2007
jyzz is offline
post #8 of 8 Old 03-05-2013, 03:38 PM - Thread Starter
AnthonyB's Avatar
I made the Xbox HD-DVD drive into an IDE with some grinding and soldering. Fun project. Fried a motherboard and a drive in the process. At one point, I was totally committed to making it work.. Buying the Blu-ray burner for about $600 made the budget tight so I got it done.
I'll be selling it on eBay soon.
AnthonyB is offline
Reply Home Theater Computers
