Help! Driver and MPC/LAV problem. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2013, 10:00 AM - Thread Starter
AnthonyB's Avatar
Driver Sweeper ruined my LAV Codecs!
I had a bunch of problems with the NVIDIA forceware 310.90 and it was causing a lot of BSODs so, I uninstalled, restarted, uninstalled Audio, ran driversweeper, and then re-installed the 307 forceware.
Now, I cannot run MPC-HC because it gives me a no connector pin error for audio.
I did uninstall LAV and re-install it but that didn't help at all.
AnthonyB is offline
post #2 of 4 Old 02-12-2013, 10:04 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #3 of 4 Old 02-12-2013, 11:55 AM - Thread Starter
AnthonyB's Avatar
Forget it. Restored to a backup.
My BIOS was the first to come out on this motherboard so I updated it. Hopefully this may help the bsod issue.
Its an irq_not less or equal.
The crash dumps all indicate a video card driver problem. After I restored I downgraded my drivers to a 306 series and that didn't help either. That is when I decided to upgrade the bios.
MPC-HC crashed instantly when I tried to open a BR ISO right before I decided to update it
AnthonyB is offline
post #4 of 4 Old 02-12-2013, 09:22 PM - Thread Starter
AnthonyB's Avatar
To many bsods. It only happens with the PCI IDE card in.. Guess I won't be watching discs until I figure out a better way to connect my Blu-ray player up.
Looking at the rosewill IDE bridge card to sata converter
AnthonyB is offline
Reply Home Theater Computers
