Custom HTPC with touchscreen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-13-2013, 07:42 AM - Thread Starter
crazymexican33's Avatar
I have been looking for ages for a decent HTPC case. I've been dissatisfied with what is available and the ones that I do like are way too expensive. So I've decided that I will mod an existing case to get what I want at a more affordable price.
These are the parts I am looking at.
Lian Li PC-C60 USB 3.0 HTPC case
Silverstone MFP51 IR reciever with display
Griffin PowerMate, USB Multimedia Controller Knob
http://www.ebay.com.au/itm/Griffin-PowerMate-USB-Multimedia-Controller-Knob-NEW-/290668941557?pt=AU_Input_Peripherals&hash=item43ad3810f5
7inch TFT LCD Touch Screen 1080p
http://www.ebay.com.au/itm/7inch-TFT-LCD-Touch-Screen-On-Camera-HD-Monitor-with-1080P-HDMI-DVI-VGA-AV-Input-/110999121379?pt=LH_DefaultDomain_3&hash=item19d8102de3
Here's a mock up of what the build will look like. I'll be using the black version of the lian li case though
I'm not sure whether to mount the display as it is or remove the screens housing and mount it flush with the front of the case.
Please share any ideas.
crazymexican33 is offline
post #2 of 7 Old 02-13-2013, 07:58 AM
DavidT99's Avatar
Quoted: 13 Post(s)
A question..............why would you have a touchscreen on an HTPC, surely the idea of an HTPC is to control it from the couch. Do you have very long arms. smile.gif
David
Sammy2 likes this.
DavidT99 is offline
post #3 of 7 Old 02-13-2013, 08:17 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
David
Can't really add much to that.
Sammy2 is offline
post #4 of 7 Old 02-13-2013, 08:23 AM - Thread Starter
There are a number of uses. When Listening to music I'm not going to have my TV running am I. And then when I want to Choose a song i'm not going to sit at my couch with a remote squinting at the touchsceen. Derrr.
post #5 of 7 Old 02-13-2013, 08:35 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Okay. I have my HTPC in an enclosure with solid doors that remain closed. I use my remote and then select and control music while looking at my TV, but I can see your point too.
Sammy2 is offline
post #6 of 7 Old 02-13-2013, 08:37 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
I think that if you remove the display from the housing and do a flush mount it will look nicer if the edges of the case look finished enough to do that. It is a Lian Li so I presume it is finished.
Sammy2 is offline
post #7 of 7 Old 02-13-2013, 09:33 AM
DavidT99's Avatar
Quoted: 13 Post(s)
I can do this too with a remote app on my Android tablet and phone. I believe there are also apps available for the iPhones.I use XBMC as my front end but presumably there are similar apps available for MP and WMC smile.gif.
To each their own, its your money. I admit it will look cool and impress your family / friends. biggrin.gif
David
DavidT99 is offline
Reply Home Theater Computers
