Change time that TV Archive runs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-14-2013, 05:22 AM - Thread Starter
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Is there a way to change the time that the TV Archive runs? I seem to be having a problem where my HTPC is archiving my recorded shows the same time as FlexRaid is trying to update its parity and FlexRaid then fails the update. I've already moved my computer backups to another time because they had been intering as well. I'd prefer not to move the FlexRaid update if possible.
Carty Custom Builders, LLC
ncarty97 is offline
post #2 of 3 Old 02-16-2013, 12:04 AM
Puwaha's Avatar
Liked: 35
As far as I can tell, no.
Something you could do though... is to setup scheduled tasks on your HTPC to enable the archive service at your allotted time, and then turn it off before your FlexRAID parity time starts. If it's in the middle of a move, the service will start over on that file when it's running again.
Puwaha is offline
post #3 of 3 Old 02-16-2013, 12:09 PM - Thread Starter
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Turns out it wasn't an issue with the TV Archive, it was just coincidence that I had enabled the TV Archive the same time. The issue was that a file in a DVD I had ripped had an issue. FlexRaid was reporting it as 'Slippery' whatever that means. I deleted the DVD and reripped and no more issue!
ncarty97 is offline
Reply Home Theater Computers
