*WOW* ... SVP +1080p Animation = OMG ! (60 frames per second for the win!) - Page 23 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #661 of 694 Old 06-05-2014, 09:34 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
4K support = SVP 64bit (almost). I haven't heard of it.
renethx is offline
post #662 of 694 Old 06-06-2014, 07:40 AM
pylor's Avatar
Quoted: 27 Post(s)
Interesting that there's a software dedicated to this. Maybe I'll try it out sometime, it'd be nice if it didn't make me feel sick to my stomach though. Every single TV implementation of smooth video gives me headaches and makes me nauseous. I have no problem with 60fps (infact I enjoy it), but when something is interpolated from 24->60fps it always seems to have this sort of "fluid motion" as I call it that makes it look fake, like it's too "smooth" to be real..
pylor is offline
post #663 of 694 Old 06-07-2014, 05:03 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Compare:
[F4. FHD 48fps] The Hobbit (2012) - Trailer.flv (original 48fps)
[F4. FHD 60fps] The Hobbit (2012) - Trailer.mkv (original 48fps -> 24fps by dropping half the frames -> 60fps by InterFrame)
in this folder. The former is from the original 48fps film. The latter was created by InterFrame (= a non-realtime version of SVP, roughly) from [F4. FHD 24fps] The Hobbit (2012) - Trailer.mp4, and that's how SVP looks like. Aside from usual "oily effects", it may look quite unnatural. But even the original 48fps may look unnatural (because of the lack of motion blur and strobing artifacts).
Another example:
[F4. FHD 24fps] Tangled (2010).mkv (original)
[F4. FHD 60fps] Tangled (2010).mkv (created by InterFrame)
I like the latter a lot.
renethx is offline
post #664 of 694 Old 06-07-2014, 03:39 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Somehow the folder share was set to private. It's now public. Enjoy the beauty or ugliness of SVP (or InterFrame).
renethx is offline
post #665 of 694 Old 06-09-2014, 04:46 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by renethx View Post
Compare:
Another example:
Those are hard to download. I could not figure out what I needed to click, everything looks like it but really is an advertisement. Or it required a facebook or gmail account... or twitter...
Can you just load them into dropbox or like free cloud storage account ? and post the public direct download link ?
Mfusick is offline
post #666 of 694 Old 06-09-2014, 07:39 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
If you have a SNS account, download begins with a few mouse clicks, pretty easy (ignore "Premium", that requires a paid account).
How about MediaFire?
renethx is offline
post #667 of 694 Old 06-10-2014, 08:48 AM
utee05's Avatar
Quoted: 30 Post(s)
So I have 2 rigs that I can test this on. One is my main gaming rig that has a i7-4770k OC to 4.5Ghz with 16gb ram and GTX780. I have another mild HTPC with a10-5800k and r7 260x. I have madVR set at lvl5 for both of these but now am going to give SVP a try.
Is there a chart of the list of settings of which to start off with and tweak in SVP as I go along? Thanks.
utee05 is offline
post #668 of 694 Old 06-10-2014, 03:59 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
For starters, try preset levels of SVP (video profiles > reset to defaults). Make sure GPU-acceleration (OpenCL) is enabled. FYI the best combination of madVR / SVP levels for each source/target resolution is:
For A10-5800K, you may have to lower SVP level by one-two rank as compared with Core i3. GTX 780 is equivalent to R9 270X in madVR/SVP performance (OpenCL support in NVIDIA cards is not so good).
renethx is offline
post #669 of 694 Old 06-23-2014, 01:01 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Love your charts
Thumbs up every time!
It is interesting to see the wattage ^
I noticed you step down the levels on the i3 which probably lowers the wattage. What happens if you keep the level higher with the i3 ? (CPU does not look maxed out, might go another level up?)
It's not really fair to compare a dual core on level 2 to a quad core on level 5 for wattage IMO.
Mfusick is offline
post #670 of 694 Old 06-23-2014, 01:30 PM
TheFranchise's Avatar
Liked: 31
Also, one of those is using a 260x while the other is a 270x. When gaming on those, that's a 30-35 watt difference right there. It's harder to figure out the difference for SVP though since the 270x is (usually) operating at a lower usage % than the 260x.
TheFranchise is offline
post #671 of 694 Old 06-23-2014, 02:35 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yeah my point or question was centered more around the idea that a higher end CPU and GPU on higher settings should consume more power- they are doing more work. I was curious if the i3 would consume the same power if it was doing the same work or not ?
A lot of people think powerful CPU automatically consume a lot more power, but if they are not very high usage it's not really true. My i7 desktop cruises around at 800mhz and consumes less power than my Celeron G530 on the killawatt if the GPU card is off (or removed).
Mfusick is offline
post #672 of 694 Old 06-24-2014, 12:46 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Core i3 can't handle SVP level 5g for 1080p24 movies. The chart represents the best combination of SVP and madVR levels each combination of CPU and GPU can handle. I am not going to test all possible CPU/GPU combinations, it's simply unneccessary because we can infer the result (except for power consumption) easily.
The 'preset' SVP levels are not suited for the current crop of CPUs (I mean 'Haswell'). Core i3 can handle Level 5g for 480p and 720p, but can't for 1080p (then 5g for 480p/720p had better be renamed to 4g). Core i5 can handle Level 5g for up to 1080p easily, let alone Core i7. Then ...
Mfusick likes this.
renethx is offline
post #673 of 694 Old 07-11-2014, 07:29 AM
HDTN's Avatar
I think SVP is great and learned a lot reading this forum. I had a question about what video card would be good for SVP. I am using a FX-8350 and a GT520 video card. My Cpu usage for 16:9 1080p is 50 to 60% cpu usage at 5g and 40 to 50% cpu usage for wider aspect ratio 1080p movies like 2:35:1. The GPU load is running at 50 to 80%. I have Gpu acceleration enabled of course. I am using EVR render. I was wanting to know if upgrading to a Radeon R7 240 or 7770 would take more load off my cpu and provide richer color and better picture. My picture is good it just seems the color isn't as rich as it should be. I heard that some Nvidia video cards have RGB issues. I also though if I switch to a Radeon card that might make the color richer. Also my fps seem to be weaker compared to others when I run SVP mark. I was thinking upgrading to a better video card might help with this. Here are my SVP results:
Test summary
Date: 2014-07-02T17:50:43
CPU: AMD FX-8350 Eight-Core @4027 MHz [8 threads]
GPU: NVIDIA GeForce GT 520 [ver.337.88]
Mode: FHD + GPU [17 threads]
Overall scores
Synthetic CPU: MC2233
Synthetic GPU: MG2536
Real-life: FG1531
Details: synthetic
CPU: compose (single-threaded): 402
CPU: compose (multi-threaded): 2217
CPU: search (single-threaded): 488
CPU: search (multi-threaded): 2250
GPU: system -> GPU transfer: 1031
GPU: GPU -> system transfer: 858
GPU: calculations: 158
GPU: total score: 1268
Details: real-life /FHD
decode video: 9.78x (234.7 fps)
48 fps - vectors search: 1.52x (73.0 fps)
60 fps - frame composition: 1.22x (73.2 fps)
48 fps - [SVP] fastest: 2.91x (139.5 fps)
48 fps - [SVP] simple 1: 2.52x (120.9 fps)
60 fps - [SVP] good: 1.40x (83.9 fps)
60 fps - [SVP] high: 1.12x (67.4 fps)
60 fps - [SVP] highest: 0.74x (44.5 fps)
72 fps - [SVP] simple 2: 1.51x (108.9 fps)
Also my cpu temp was around 60c and I read on here to disable CPB and the temps went down to around 50c. Thanks to renethx for that tip.
I do not plan on using MadVR just EVR render. Any advice would be appreciated.
HDTN is offline
post #674 of 694 Old 07-11-2014, 08:57 AM
Liked: 31
Have you already tried increasing the vibrance/saturation in the video card driver settings?
You may also have the colorspace set wrong for TV vs. monitor output. 0-255, 16-235. On one TV, and my ATI card, I was getting either too much blacks or faded everything. So far, the only fix was putting the FFdshow filter's output to RGB32. Looks great now.
post #675 of 694 Old 07-11-2014, 10:49 AM
HDTN's Avatar
Faded is a good word to describe my color. I have tried both 0-255 and 16-235 before in the Nvidia control panel that didn't help. I also set the video card to YCbCR 4:4:4 and that made the color look better but still not that great like with a blu-ray player or STB. Also I am using ffdshow raw filter and Lav Video decoder and I didn't know if you were supposed to change the colorspace in ffdshow and Lav decoder also or just in the Nvidia control panel or what? When I hook up the pc to the tv again I will try your suggestion.
HDTN is offline
post #676 of 694 Old 07-11-2014, 11:23 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Try madLevelsTweaker.exe included in madVR (it works without madVR). Leave color space conversion options in ffdshow raw video filter / LAV video decoder untouched.
renethx is offline
post #677 of 694 Old 07-11-2014, 01:08 PM
Liked: 31
Just FFdshow raw filter. Towards the bottom in Output. And then you can mess around in the RGB Conversion tab for TV and PC levels, though I'd have to check again because I don't think changing those settings did much if anything on mine. Maybe mine's set on "auto" somewhere. I just did this the other day, so I haven't messed with it more yet.
Checkmarking RGB32 finally made the picture look as good as I expected it to be.
When you play a video, mouse over the FFdshow icon in the corner to see that it's outputting in RGB32.
Worked great for the one of my ATI cards that was giving me a hassle. Whether it fixes your output, I guess we'll see.
post #678 of 694 Old 07-11-2014, 01:11 PM
HDTN's Avatar
I will try madLevelsTweaker.exe also. Where is safe site to dowload it from? Also is GT520 fast enough for 120fps output at 5g?
HDTN is offline
post #679 of 694 Old 07-11-2014, 06:05 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
It comes with MadVR. Use link from the first post in the mpchc sticky thread in this forum.
Mfusick is offline
post #680 of 694 Old 07-11-2014, 08:55 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
madVR.
I have no idea. Generally CPU is the main limiting factor (and FX-8350 should be fast enough), GPU is only subsidiary.
renethx is offline
post #681 of 694 Old 07-22-2014, 11:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Probably on 5C. 5G you might want to test. C is lighter on the GPU than G. I did not find SVP was hard on GPU like it was on CPU, but with madvR too.. it might be.
Mfusick is offline
post #682 of 694 Old 07-22-2014, 12:16 PM
HDTN's Avatar
I don't have monitor or tv that does 120fps yet. I was thinking of more in the future. I will keep that in mind about trying 5c for 120fps. I tried the madlevelsTweaker and it never change the color on my tv even after rebooting. I get the best picture by setting my video card to YCbCR 4:4:4 but it seem like there should be a little more color to the picture. I wanting to ask if anyone uses SVP for live broadcast television(football, sitcoms) with good results?
HDTN is offline
post #683 of 694 Old 08-06-2014, 09:36 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
im not sure how you'd use it live?
Mfusick is offline
post #684 of 694 Old 08-08-2014, 07:56 AM
HDTN's Avatar
You can use a OTA or DVB-S2 tuner connected to the pc via pcie or usb. The live tv signal is sent to software that can play the video. Such as SmartDVB or other software video players that can play these signals. I could never get the video to play smooth with SVP . I think it has something to do with some signals being interlaced and something about Telecine or Inverse Telecine. I don't know much about that subject.
HDTN is offline
post #685 of 694 Old 08-08-2014, 11:19 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I know you can use SVP on youtube video's which is kind of cool (but often not necessary)
Mfusick is offline
post #686 of 694 Old 09-13-2014, 07:02 AM
RedJohn's Avatar
A week ago I had built my own gaming PC, yesterday I've installed SVP and I put full max settings on madvr it looks awesome. It's sad that I'm sensitive to those artifacts though.
I do have a question, what do you think about the 'cinema' group of people who hate motion interpolation and that it ruins the 'intention' of the film and director? I'm a perfectionist and someone who doubts a lot, sometimes I put it back to 24 fps and sometimes back to 60 fps.
The true intent of 24 fps was because in the early days hollywoord made films on the lowest cost budget to create framerates right? That made it a little watchable for the public.
RedJohn is offline
post #687 of 694 Old 09-13-2014, 07:23 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Well I can tell you that the 60fps 4k demonstration Christie Projection gave me yesterday with 60foot lamberts almost ripped my face off. Literally my face was numb. It was easily the best projected image I've ever seen. The demo was showcasing they support 60fps and 120hz @4k at the light output of a supernova. If I had an extra million dollars I would get one installed in my house. Consumer level stuff is great but it's not the same as a commercial product the size of a small SUV. But I saw several trailers first at 4k and nothing looked as amazing as the 60FPS demo. There is something there.
Mfusick is offline
post #688 of 694 Old 09-13-2014, 02:18 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
If one had outregeous CPU/GPU power, could one run a SVP profile at 120fps vs 60fps?
Also, what thread would you guys recommend I post my hardware specs to ask for assistance in maximizing my SVP experience?
popalock is offline
post #689 of 694 Old 09-17-2014, 07:16 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Do it right here brotha!
ReneTHX is a great resource, especially on hardware. There is some charts hanging around that show the levels and hardware pretty well. What are your specs?
120fps is not possible (yet) to my knowledge, only 60fps. The effect is rather severe though, 120fps might be overkill.
If you've seen 48fps (which I like) 60FPS is noticable the difference. Film is only 24fps so taking it to 60fps is really obvious when you do it. I'd say it's actually so obvious that some don't care for it.
Mfusick is offline
post #690 of 694 Old 12-19-2014, 02:05 PM
Luis Gabriel Gerena's Avatar
Quoted: 94 Post(s)
Liked: 63
Guys, I am really interested in this for my W1070 projector.
Unfortunately my HTPC is only running a Core 2 Duo E8600 Overclocked and I just got a GTX 750Ti for it. Is my CPU completely going to kill my SVP experience or is there hope that the 750Ti will help?
This is exclusively for Bluray playback.
I do have a CPU I have left over from my main PC (1366 i7 920) which I used to run at 4Ghz but I would need to invest on a mobo and triple channel ram for it so I was hoping for a miracle based on my GPU instead of my old 775 platform.
What you guys think?
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
Reply Home Theater Computers
Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desktop Processor , Amd A6 3650 2 6ghz Socket Fm1 Quad Core Desktop Apu Cpu Gpu With Directx 11 Graphic , Intel Core I7 4770k 3 5ghz Lga 1150 Quad Core Desktop Processor
