MPC-HC and greenish tint - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-16-2013, 03:34 PM - Thread Starter
Tony359's Avatar
Quoted: 60 Post(s)
Hello all,
I am using MPC-HC with MadVR. I have calibrated my screen using yCMS. Primaries and grayscale are ok if I check the calibrated result but the overall picture look greenish. Nothing terrible, but I do believe those are not the right colours. Disabling the yCMS calibration does not change the greenish tint - only the primaries go back to the original values (oversaturated, it's a "wide gamut" screen).
I have the feeling the colour space may be the wrong one, but I tried all possible options with no luck.
Under LAV Video Decoder it looks like it's not active, because the active decoder says "none".
Any suggestions?
Tony
Tony359 is offline
post #2 of 3 Old 02-23-2013, 05:30 AM - Thread Starter
Tony359's Avatar
Quoted: 60 Post(s)
anybody can help?
Tony359 is offline
post #3 of 3 Old 02-23-2013, 12:08 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Are you using HDMI? This looks like it is possibly an HDCP and/or EDID issue.
Sammy2 is offline
Reply Home Theater Computers
