HTPC + NAS proposed build review requested - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 03-10-2013, 04:09 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
^^ Optical won't give you HD audio. Going analogue won't give you a lot of the DSP features in AVRs, but what depends on what AVR it is.
My advice would be a new AVR with HDMI.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #32 of 34 Old 03-10-2013, 04:24 PM
A9X-308's Avatar
Liked: 1142
Originally Posted by balky View Post
Depending on what you need your NAS for... it is mostly better to have two separate machines... each one dedicated to its own task...
If the NAS will serve only one HTPC connected to the TV or AVR, it surely makes sense to have both on only one machine...
If the NAS will serve 3 smart TVs, two HTPCs, an iPhone, two iPads, family documents, tv recordings...etc... I think it is clear what the better choice should be...
Originally Posted by Mfusick View Post
I just like it better. I find the server to be most reliable when it's a pure server running 24/7 and needs almost no attention. The HTPC on the other hand gets used, turned off, restarted ect... none of which effect the server or stop a stream.
I should have thought past my requirements to what others use and why they make their decisions, and the answers you gave would have been bleedingly obvious.
My situation is somewhat unique in that I have a 1 person household so I want the HTPC/NAS to store movies/music and one of the backups of my personal data. No one else will be using it at other times so there is no need for 24/7 access to files on it. If I'm at work or not actually accessing the drives on it, it will be in sleep mode to save power. So, unless I've missed something obvious again, a combined unit will work for me. I have many of the pieces picked, but will discontinue the threadjack and ask in my own thread shortly. Cheers.
A9X-308 is offline
post #33 of 34 Old 03-11-2013, 12:10 PM
balky's Avatar
Quoted: 252 Post(s)
Liked: 170
For a 1 person household, it is really a waste of resources running more than one machine...IMO
balky is offline
post #34 of 34 Old 03-12-2013, 05:23 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
That depends. I love my set up. It's more expensive for sure but it's clearly better.
I think it depends on the person and what they want.
Your right if all you need is simple video playback. Or some basic storage.
Mfusick is offline
Reply Home Theater Computers
