Recommend a HTPC Case - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-20-2013, 08:48 AM - Thread Starter
123
123's Avatar
Hi guys,
Looking to transfer my HTPC from a standard mid-size micro-ATX/ATX case into a HTPC case. I've searched around on newegg a bit but thought I'd ask for some input here as well. Here are my requirements, in order of importance:
1.) Box style (to match my AVR) w/ MicroATX form factor
2.) Width <= 20"
3.) Height <= 6"
4.) USB 3.0 ports
5.) Price <= $80
6.) Color = black
Appreciate any suggestions. Thanks.
123 is offline
post #2 of 12 Old 02-20-2013, 09:54 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Silverstone 03 for $59
Mfusick is offline
post #3 of 12 Old 02-20-2013, 10:12 AM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 61 Post(s)
Liked: 98
+1 on the Silverstone ML03 (Milo). Just be sure to download the manual here to get the component specs. There are size limitations on PSU and ODD, as well as cooler height.
http://www.silverstonetek.com/product.php?pid=283&area=usa
wiley165 is offline
post #4 of 12 Old 02-20-2013, 10:17 AM
dschlic1's Avatar
Quoted: 125 Post(s)
Liked: 39
I am currently looking at the Apex DM-532:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154114
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #5 of 12 Old 02-20-2013, 10:29 AM - Thread Starter
123
123's Avatar
awesome, thanks guys. Will look into them. I guess I didn't consider that I already have components, and would like them to fit as well.
123 is offline
post #6 of 12 Old 02-20-2013, 01:51 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Milo 03 is probably the best case for $60 IMO.
Mfusick is offline
post #7 of 12 Old 02-20-2013, 03:29 PM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
I've got that Silverstone case and it's awesome, but it gets tight in there. I used an SFX power supply in mine http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=22_160&products_id=28447 to make sure I had enough room for the OD. If you use a full ATX PSU I would make it a modular one, even then you will probably need right angle power & SATA cables. There is enough room for 3-4 80mm fans on the right side but you really only need 1-2. The case has plenty of ventilation.
Dropkick Murphy is offline
post #8 of 12 Old 02-21-2013, 06:41 AM
Socio's Avatar
Quoted: 46 Post(s)
Liked: 26
If you want something a little different you might like the Microcosm case.
The dimensions are 9.5 inches wide, 8.3 inches deep, and just 4.5 inches tall (4.75 inches tall with attached acrylic feet).
Socio is offline
post #9 of 12 Old 02-21-2013, 07:01 AM
wiley165's Avatar
Quoted: 61 Post(s)
Liked: 98
Here's a couple threads of the MILO in action...
http://www.avsforum.com/t/1419411/silverstone-ml03b-or-nmediapc-1080p-case#post_22855708
http://www.avsforum.com/t/931459/show-your-htpc-setup/960#post_22783107
Neither of these builds include a modular PSU. At the same time, they both do not have a bunch of HDD's stuffed in as well.
I can say on mine, (1st link) it no no longer looks that way. I jettisoned the plastic SSD mount, and instead mounted the SSD on the bottom of the chassis between the ODD and PSU. The HDD I had in there is removed as well (moved to new server). The extra cabling is routed under the ODD, and bundled up the extra cabling where the plastic mount was to improve airflow.
I think the biggest point to express is that these smaller cases require a bit more planning and tinkering. One decision will essentially affect something else. I thinks the specs indicate that there is room for 1 ODD, up to 3 HDD's, and up to 5 SSD's. But you can't have all of them.
wiley165 is offline
post #10 of 12 Old 02-21-2013, 09:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
I used a $19 coolermaster PSU 430 watt in my brothers. Worked great. Fit great.
really good low cost solution.
Mfusick is offline
post #11 of 12 Old 02-21-2013, 03:25 PM - Thread Starter
123
123's Avatar
Thanks for all the tips and new considerations, fellas. My PSU is NOT modular. However, I only have 1 ODD and 1 HDD currently, with no real plans to expand that other than maybe adding a SSD. I could lose the ODD as well, as I don't really use it outside of installing OS/software. I'm going to gut my rig this weekend and measure components and compare to the specs provided for the cases (looks like I'm leaning towards the milo) just to make sure everything will fit ok. I'll post up with my components and my results when I do so.
123 is offline
post #12 of 12 Old 02-21-2013, 04:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
good luck.
We like pictures.
Mfusick is offline
Reply Home Theater Computers
