madVR v0.86.0 released - with Smooth Motion - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 133 Old 03-18-2014, 08:52 PM
pokekevin's Avatar
Liked: 102
Originally Posted by renethx View Post
"Smooth motion frame rate conversion" repeats and blends frames in accordance with "whatever" refresh rate is. The underlying algorithm is due to madshi. Generally the bigger the difference between the refresh rate and the frame rate is, the cleaner the image is. So, for example, 24fps video playback in a 25Hz display with "smooth motion frame rate conversion" is smooth but blurred. 24fps video playback in a 60Hz display is smooth and clean.
Hmmm but if one has a "good" 24p set than one wouldn't benefit from this correct?
pokekevin is offline
post #122 of 133 Old 03-18-2014, 09:14 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
If your graphics card supports precise 23.976Hz, you shouldn't bother with this.
renethx is offline
post #123 of 133 Old 04-07-2014, 12:26 PM
pasiniskanen's Avatar
Hi,
Found out that 23Hz capability of tv might not be enough for "best" performance. Even though my Panasonic 65VT30 supports it, I got better results with tv set to 59HZ with Smooth Motion ON. Other settings were as in MINDBOMBS mpc-ht advanced setup guide (with ReClock).
madshi, you rock!
Btw, great thread, guys, and thanks to Steelman1991 for recommending the 23Hz/59Hz Smooth Motion ON/OFF test.
Best regards,
Pasi Niskanen, Helsinki, Finland
pasiniskanen is offline
post #124 of 133 Old 04-08-2014, 03:33 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Some TVs claim 23Hz/24Hz compatibility, but in fact they just convert to 60Hz internally - in which case its indeed better to use Smooth Motion.
Nevcairiel is offline
post #125 of 133 Old 04-08-2014, 03:45 AM
TV is Panny's flagship from 2011 (if I remember correctly), and it really does support real 23/24p.
I tried 23p (without Smooth Motion) and turned TV's Smooth Cinema (23p/24p@93Hz) ON, and got even better result with the rolling test image (SmoothMotion23.ytp), no judder at all, but the downside was heavy pixelation of the high contrast black-white bars. Will keep this setting for a few weeks and see whether the pixelation issue persists with real life content.
A quick test with Hobbit:DoS found a scene with panning and high contrast: Thorin's hair against a grey/white sky, and some pixelation was indeed visible. Then again, that might be the only scene with pixelation in a 3hr movie. I could live with it. I dislike judder more... Obviously the picture seems less "movie-like" (if you know what I mean), but I think I rather go with the "realistic" look without judder...
post #126 of 133 Old 04-08-2014, 04:25 AM - Thread Starter
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
Same telly - what you will find is that the trade-off (using Pana's Smooth Cinema) will be the introduction of artifacts throughout playback (pixelation and 'oily/ghosty' images just some that will appear). Its not an effect I like to watch - just too smooth and artificial for my liking, but its you who has to judge and watch the content, so each to their own.
pasiniskanen likes this.
steelman1991 is offline
post #127 of 133 Old 04-08-2014, 08:09 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Hi,
madshi, you rock!
Best regards,
The 96 Hz mode doesn't work well on those TV's, and they should be set to 60 Hz. The TV's 3:2 pulldown however is basically perfect. I'm guessing that sending 23.976 to the TV (in 60 Hz mode) vs. using Smooth Motion would produce virtually the same results.
lockdown571 is online now
post #128 of 133 Old 04-08-2014, 01:06 PM
Just watched Wolf of Wall Street. After five minutes I decided to turn off Pana's Smooth Cinema, just didn't seem right. I went back to using madVR's Smooth Motion ON (with ReClock) with telly set to 59Hz. Seems that's the best setting I've found so far. How about you?
post #129 of 133 Old 04-08-2014, 02:48 PM - Thread Starter
Quoted: 211 Post(s)
Liked: 116
Yeah when I use madVR (which frankly isn't an awful lot), that's the set-up I use, though I agree with Lockdown - Panasonic really nailed the 3:2 pulldown on this set and there is little if anything to choose between them. What I have found is to get a setting and stick with it, too much tinkering is likely to drive you bananas - like me.
lockdown571 likes this.
post #130 of 133 Old 09-01-2014, 10:47 AM
Livin's Avatar
Quoted: 189 Post(s)
Liked: 51
Can anyone help with the best MadVR settings when using an AMD / ATI 7460M (laptop) ?
content is mainly 720p, 1080i (live broadcast), and some 1080p
thanks!
________
Ltek
setup: Kodi, Paradigm-Velodyne-SVS, 120" DIY Spandex Screen, Sony 45ES
Livin is offline
post #131 of 133 Old 09-02-2014, 02:53 AM
thanks!
Have you tried MINDBOMB's Advanced MPC-HC Setup Guide w/ MadVR?
post #132 of 133 Old 09-08-2014, 07:35 AM
Livin's Avatar
Quoted: 189 Post(s)
Liked: 51
That write up is a setup/install... does not help guide people to the proper settings for their CPU & GPU.
This is why I'm asking for people's input.
________
Ltek
Livin is offline
post #133 of 133 Old 09-08-2014, 07:49 AM
Ok, fair enough. I felt that the section "MadVR Config" gave good advice for choosing and testing settings, and also for judging performance.
Reply Home Theater Computers
