AMD A6-3500 3DBD problem CPU usage - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2013, 02:34 PM - Thread Starter
Bazto's Avatar
Hey guys and greetings from germany,
i have a problem with my HTPC and the reason why I signed into this forum is a post I found after a google research on my problem. As I tried to find help in several forums with bad luck I decided to ask someone who actually has my CPU working.
To my problem:
I have got a HTPC (~1 year) with the following hardware:
- AMD A6-3500
- ASRock A75M-HVS
- 4 GB RAM
- no seperate GPU
- LiteON IHOS104
and the system worked out fine for me. When I built this PC last year I searched for a CPU which is able to play 3DBD and due to several postings I bought the A6.
Last week I got a new LCD (LG 55LM620S) which is able to play 3D (passive). And this is where my problem starts biggrin.gif
Yesterday I rented a 3D BluRay and wanted to play it with PowerDVD12 and my CPU usage goes up to 100%. Hardware acceleration is activated as it says in the settings.
My first guess was, that the CPU is not strong enough for the BluRay playback, but I have a .mkv video of Avatar in 3D and I played it with the MPC-HC and the K-Lite Codes Package. It works just fine with a CPU usage of ~20 - 30%. Then I found the following post via google:
Originally Posted by renethx View Post
A6-3500 (and any other Llano APU) supports BR 3D with HDMI 1.4a 3D video (Frame packing) output perfectly. CPU usage:
- BR 3D Hardware acceleration On: ~25%
- BR 3D Hardware acceleration Off: ~85%
- 1080p24 2D->3D conversion: ~75%
Triple core @2.1GHz is a bit weak for 2D->3D conversion (I would like to see CPU usage
So i guess there must be a possibility for me to get the BD's running and I would be glad if someone (maybe Renethx wink.gif) could help me with this problem.
Maybe there are some special drivers or settings I missed to install.
Bazto is offline
Old 02-22-2013, 02:49 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Uncheck "Enforce smooth video playback" (this post)?
Personally I would disable all video post-processors except for deinterlacing and pulldown detection.
renethx is offline
Old 02-22-2013, 02:56 PM - Thread Starter
Bazto's Avatar
Alright I directly adressed the right person smile.gif i will give it a try later on and report smile.gif
Bazto is offline
Old 02-22-2013, 04:22 PM
ilaurens's Avatar
You can try this: http://www.svp-team.com/wiki/Quick_start
But I do not know if it will work with PowerDVD, Worth a try though. Before you install this delete K-Lite codec, If you have that installed.
ilaurens is offline
Old 02-23-2013, 02:43 AM - Thread Starter
Bazto's Avatar
@renethx: Thanks again for the quick reply. I gave it a try today and it really seems to work. I don't have a BluRay at home at the moment but I will organise one in a couple of hours. Nevertheless I got a .iso in 3D and I mean to remember I had the same problems. And now it works smile.gif
Just one more question: in this thread you linked to is said:
Originally Posted by e2zippo1 View Post
In PowerDVD this is the information I get
Hardware Information:
Processsor: AMD A6-3500 APU with Radeon(tm) HD Graphics running at 2100MHz
3DNow! technology: In Use
Enhanced 3DNow! technology: In Use
3DNow! professional technology: In Use
IA MMX technology: In Use
IA sStreaming SIMD extentions: In Use
IA SSE 2: In Use
Video Accelerator: DirextX VA (not in use)
Where can I find this information to double check my settings?
I will report when I have a real BluRay but I am quite optimistic. Why the hell is this the default setting in CCC? biggrin.gif
Alright, thanks a lot so far and I will run some tests later on.
Bazto is offline
Old 02-23-2013, 05:17 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
PowerDVD > Settings > Information.
renethx is offline
Old 02-23-2013, 08:41 AM - Thread Starter
Bazto's Avatar
So, I just rented Pirates of the Carribean in 3D and seems to work fine with a CPU usage of 27% smile.gif
Thanks alot guys for the fast help. You saved me lots of time and money wink.gif
Bazto is offline
