Bluray ISO on Windows 7? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-22-2013, 04:20 PM - Thread Starter
rferrar1's Avatar
Is there a simple way to play blu-ray ISO's on a windows 7 machine? Even better, is it somehow possible within XBMC?
rferrar1 is offline
post #2 of 13 Old 02-22-2013, 04:40 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You need a virtual drive first. Then just a player/software.
Not hard at all.
Try mounting clone drive:
http://static.slysoft.com/SetupVirtualCloneDrive.exe
That should allow you to play ISO
Mfusick is offline
post #3 of 13 Old 02-22-2013, 04:42 PM
Postmoderndesign's Avatar
Quoted: 216 Post(s)
Liked: 85
I do not know about XBMC which I think can use MPC-HC. MPC-HC can play a blu-ray iso.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #4 of 13 Old 02-22-2013, 05:27 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
both mediabrowser and XBMC can use an external player like MPC-HC. (or VLC, )
But proper way to play ISO is to mount a virtual drive.
Mfusick is offline
post #5 of 13 Old 02-22-2013, 09:36 PM
Quoted: 216 Post(s)
Liked: 85
Correct, you do need to mount the iso first. Slysoft virtual clone drive will mount the iso on the drive letter you specify and then you need to navigate to that drive and select the iso.
post #6 of 13 Old 02-22-2013, 11:10 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Is that a recent development? Last I used MPC-HC it couldn't even play DVD ISOs (without mounting them first). VLC can mount ISOs directly.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #7 of 13 Old 02-23-2013, 01:12 PM
sycochkn's Avatar
XBMC 11 and 12 play bluray iso. PowerDVD and TMT will play bluray iso mounted with virtual clone drive.
sycochkn is offline
post #8 of 13 Old 02-24-2013, 12:12 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I believe the new mediabrowser 3 will have this as a core feature.
Mfusick is offline
post #9 of 13 Old 02-24-2013, 03:15 PM
Quoted: 216 Post(s)
Liked: 85
It is my understanding that it is planned for media browser 3 will include vlc as a default player. But currently you need MPC-HC to use MadVR and Jinc3 +AR which will blow you away if you have a GPU capable of jinc 3 +AR upscaling. But I do understand the need to include a player which will work for most people.
post #10 of 13 Old 02-24-2013, 04:20 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
When you say Jin3+AR what exactly do you mean ?
Are you talking about the setting in MadVR ?
If so... what is the "AR" ???
Mfusick is offline
post #11 of 13 Old 02-24-2013, 04:32 PM
Quoted: 216 Post(s)
Liked: 85
anti-ringing
The improvement will be most obvious on a DVD you are familiar with, but it helps Blu-ray as well
post #12 of 13 Old 02-24-2013, 05:34 PM
crook038's Avatar
XBMC Frod 12 can play Blue Ray ISO files. The menu screen is a bit different. I am watching 2012 blue ray ISO as I type this. I am a big fan of XBMC and feel it compliments my HTPC build. If you are reading the ISO from a network drive make sure you have a decent transfer rate or you may get buffering issues. The XBMC forum can answer any question you could throw at it.......enjoy.
Sean
crook038 is offline
post #13 of 13 Old 02-24-2013, 11:33 PM
ccrocker001's Avatar
MeediOS can also play ISO files (via the ISO Player plugin) and has a native madVR video player.
ISO Player Plugin:
http://www.meedios.com/forum/viewtopic.php?f=61&t=6406
madVR Player Plugin:
http://www.meedios.com/forum/viewtopic.php?f=61&t=7704
If you are using Virtual Clone Drive to play ISO files over a network I would recommend trying version 5.4.4.0 if you have issues with the current version of 5.4.5.0. Further discussion here:
http://forum.slysoft.com/showthread.php?t=50637
ccrocker001 is offline
Reply Home Theater Computers
