older ATI USB TV Tuner Card vs. internal modern TV tuner card - quality difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-24-2013, 05:48 PM - Thread Starter
Archaea's Avatar
Quoted: 3076 Post(s)
Liked: 2691
I have a older ATI TV tuner USB stick - the ATI 600 TV Tuner.
The blacks aren't great on it. It looks pretty washed out in comparison to other HD sources like a bluray, but it is HD, and it has smooth playback, and supports Dolby Digital - so it's not terrible. I use it exclusively for over the air tv tuning. Are the internal cards improved? How much does video quality differ from TV tuner card to TV tuner card? What's currently recommended most highly for over the air use? I'm feeding the USB card through a GTX 670 to an Epson 8350 and the regular computer display doesn't have the same washed out blacks when playing input from say CyberPower DVD etc.
Archaea is offline
post #2 of 4 Old 02-24-2013, 08:13 PM
sitlet's Avatar
Quoted: 12 Post(s)
If you are talking about OTA or QAM, there really isn't any difference. Digital is digital in this case.
sitlet is offline
post #3 of 4 Old 02-25-2013, 07:27 PM - Thread Starter
Archaea's Avatar
Liked: 2691
So washed out blacks are expected on ota cards?
Archaea is offline
post #4 of 4 Old 02-26-2013, 12:09 AM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Nope.
It could be your tuner but most likely it's a video card setting that needs to be changed, such as full range color or limited range. And if your using WMC it could be interacting or working against your video card settings.
Take a look at this thread.
http://www.avsforum.com/t/1444859/setting-nvidia-to-full-range-rgb
Mike99 is offline
Reply Home Theater Computers
