HTCP enters sleep mode while watching movie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-25-2013, 10:59 AM - Thread Starter
Dougw133's Avatar
I have a had a build for years that was quite stable. Recently if we begin to watch a movie the PC enters sleep mode at least 3-4 times before it decides to let us watch our movie. I have disabled sleep all together in the control panel yet it still continues to do this. Whether I am in Windows Media Center or stand alone Media Classic it does this. I can find no reason or explanation of why it is doing this. Any one who can at least point me where to look would be appreciated.
Dougw133 is offline
post #2 of 9 Old 02-25-2013, 01:28 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
Screen Saver ?
Andrew Hornfeck is offline
post #3 of 9 Old 02-25-2013, 08:57 PM
Puwaha's Avatar
Liked: 35
Check your advanced power options. Under the Multimedia settings is an option called "When playing video"... make sure it's set to "optimize video quality". And there is also a "When sharing media" setting, make sure it says to "prevent idling to sleep".
Puwaha is offline
post #4 of 9 Old 02-25-2013, 10:16 PM - Thread Starter
Dougw133's Avatar
There is no screen saver and the above options are already set exactly how you suggest. Occasionally I'll get a restart instead of it being in sleep mode. I have swapped the ram and no difference. Video card is an Nvidia 430. There are no issues with playback at any time. Codecs are sharks win 7 and x64 components. Still, NO clue what the heck could be going on. Pretty computer savvy and build my own systems but never had this happen before.
Dougw133 is offline
post #5 of 9 Old 02-25-2013, 10:24 PM
Puwaha's Avatar
Liked: 35
Are you sure the whole PC is going into sleep mode and it's not just turning off the screen?
What kind of video card are you using?
Puwaha is offline
post #6 of 9 Old 02-25-2013, 10:28 PM - Thread Starter
Dougw133's Avatar
Yes. It is entering sleep. "Turn off the display after x minutes" is disabled in control panel. The screen goes black and the HTPC enters sleep. The front power light begins blinking as it normally does when it sleeps and all fans are shut down. Im sure it's asleep. Card is a GT 430
Dougw133 is offline
post #7 of 9 Old 02-26-2013, 12:25 AM
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
Maybe look around for some relevant BIOS options. Change settings and see if it has an effect. I had a similar problem that turned out to be related to some obscure settings in the iMon software for my remote control. Also, the MCE standby tool might be of use to you if you're not already using it: http://slicksolutions.eu/mst.shtml.
ajkrishock is offline
post #8 of 9 Old 02-26-2013, 04:31 PM - Thread Starter
Dougw133's Avatar
What was the issue with Imon?? I have a thermaltake case that has an iMon display. Could be something to look at.
Dougw133 is offline
post #9 of 9 Old 02-26-2013, 08:57 PM
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
I don't remember off the top of my head. I'll look at it when I get home and see if I can jog my memory.
Reply Home Theater Computers
