HDMI & Display Port at the same time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-26-2013, 11:37 AM - Thread Starter
Mopar_Mudder's Avatar
Quoted: 25 Post(s)
Liked: 32
Can anyone tell me first if Audio goes through the display port? Then if it does can the HDMI and Display port be used to go to different diplays?
I want to send the HDMI to my reciever and the Display Port to my TV, I believe you can get a display port to HDMI adapter.
Mother Board is GA-H57M-USB3
Mopar_Mudder is offline
post #2 of 5 Old 02-26-2013, 03:22 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
I recall Display Port supports audio.  I would bet you can't get audio on both simultaneously, though.  WHY do you want the TV connected directly to the PC and not the receiver anyway?
Andrew Hornfeck is offline
post #3 of 5 Old 02-26-2013, 03:46 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 32
The TV is actually in a different room and the reciever goes to the projector. Actlually the computer will be hooked to 3 displays. Right now it runs to the receiver to the projector plus I use the sub out on the reciever to go to yet another display. I have a HDMI splitter in the way that I am going to try first. Just had the thought that maybe I could use the display port, but the splitter is probably easier if it works.
post #4 of 5 Old 02-26-2013, 06:56 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
DisplayPort with a passive DP-HDMI adapter like this (so actually HDMI signals will be transmitted over DP) should support HD audio bitstreaming. But this depends on each mb...
Clarkdale (and later) supports dual audio stream (over HDMI+HDMI and HDMI+DP).
renethx is offline
post #5 of 5 Old 10-20-2013, 10:12 PM
eedwards86's Avatar
I'm actually curious about this as well. Can you use a displayport to go out to TV (for 3D) and use the HDMI output to go to your receiver for HD-audio (receiver that does not support 3D, HDMI 1.4a, etc).
eedwards86 is offline
Reply Home Theater Computers
