IE10 Install problems on windows 7 - AVS Forum
post #1 of 10 Old 02-26-2013, 01:59 PM - Thread Starter
gonzo90017's Avatar
Anybody else having trouble installing Internet Explorer 10 on Windows 7? Every time I run the .exe it tells me I need some updates although Windows is up to date. The page it takes me to has some updates which I download but only 1 of them installs. The rest tell me "the update is not applicable on your computer".
gonzo90017 is offline
post #2 of 10 Old 02-26-2013, 02:34 PM
mdavej's Avatar
Quoted: 129 Post(s)
Liked: 286
No problem here. Did you pick the right version (32-bit vs. 64-bit)?
mdavej is offline
post #3 of 10 Old 02-26-2013, 02:51 PM
tomandbeth's Avatar
No problem here, either. Took about 5 minutes.
tomandbeth is offline
post #4 of 10 Old 02-26-2013, 04:59 PM - Thread Starter
gonzo90017's Avatar
Yes 32bit. Wonder what the problem is?
post #5 of 10 Old 02-26-2013, 08:22 PM
Sammy2's Avatar
Quoted: 23 Post(s)
Liked: 168
What is to be gained here over Chrome?
Sammy2 is online now
post #6 of 10 Old 02-26-2013, 08:50 PM
mdavej's Avatar
Quoted: 129 Post(s)
Liked: 286
Absolutely nothing. I gave it a try and found it even more confusing and inefficient than IE9. Seems to be microsoft's modus operandi these days. Doesn't hold a candle to Chrome. I doubt I'll ever use it again. No offense to the OP, just my opinion.
mdavej is offline
post #7 of 10 Old 02-28-2013, 10:05 AM
WylieKylie's Avatar
I had the same problem as the OP, I tried to install the reccomended updates, still no dice. I was re-installing Win 7 at the time (2-26-13) so I figure that had something to do with it. Haven't tried or worried about it since, I figure it will eventually update as one of the regular Windows uptdates.
As for the comments on other browsers, I normally use Firefox, but on my main HTPC I only use the web for updating stuff, so I don't install anything other than what is provided by Microsoft.
WylieKylie is offline
post #8 of 10 Old 02-28-2013, 06:21 PM - Thread Starter
gonzo90017's Avatar
Wish you had found a solution. The reason I want to upgrade is not to use it as my regular browser since this is for my htpc. The reason is because I want to see if it solves the stuttering I get when using Silverlight. The new twcsportsnet.com website uses silverlight as default and it's choppy as hell.
post #9 of 10 Old 03-01-2013, 04:50 AM
Josea's Avatar
OP are you already running the RC/Beta version if IE10, if so remove it first then retry installing IE10, Also look through your update history (in the Windows update dialog) to see if any updates failed, you may need to install any missing updates first before IE 10 installs. And see this link http://support.microsoft.com/kb/2818833
Just out of curiosity are you using windows update or have you D/L'ed the file manually? http://windows.microsoft.com/en-US/internet-explorer/downloads/ie-10/worldwide-languages
Josea is offline
post #10 of 10 Old 03-01-2013, 10:35 AM - Thread Starter
gonzo90017's Avatar
Thanks for your help.
I never installed the RC version but i'll take a look at my update history.
The first thing I tried was go to the link but it didn't resolve my issue.
I downloaded the file manually. I couldn't find it through windows update.
Reply Home Theater Computers
User Tag List
