Assassin's Intel NUC Review - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 08-06-2013, 03:40 PM
bluechunks's Avatar
Quoted: 85 Post(s)
Liked: 117
Originally Posted by Carisma View Post
Sorry...it was 60Hz. I was getting specs for a computer my friend wanted and he wanted it to handle 120Hz while I was typing up my post.
The only projectors I know that can do 1080p @ 120Hz are the Christie Digital's and I am not that rich haha.
I want 1080p@60Hz...again sorry for the confusion
In that case it doesn't matter if you are planning to use OpenELEC w/XBMC on a Celeron with the NUC. It will do it just fine.
If you are considering installing Windows you may wish to consider an i3. (My opinion only.)
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
1080P: Apple TV (4th gen) & Intel Nuc (LibreElec/Kodi)
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is online now
Old 08-06-2013, 04:16 PM
Carisma's Avatar
Thanks mate! Yes I would rather use Windows over Openelec, so I'll price out the i3 build and go for the cheaper one smile.gif
Carisma is offline
Old 08-07-2013, 02:24 AM
killa2009's Avatar
i have celeron with windows 8 and it runs fine.
Sent from my skz_tenderloin using Tapatalk 4
killa2009 is offline
Old 08-07-2013, 10:38 AM
space2001 is online now
Old 08-07-2013, 03:29 PM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
Guys, I need help... I'm at my wits' end with an issue in XBMC confused.gif... I'm getting weird tearing in the UI. I've tested with two displays, a cheapo Sceptre X32 LCD TV (1360x768@60Hz native) and a BenQ W1070 projector (does up to 1920x1080p@60Hz). In XBMC settings, I've tried turning on/off vertical blank sync (but left it on as suggested in XBMC forums when I searched for "tearing"). I also tried different resolutions (720p, 1080p, etc.) on both my displays. I also made sure Windows 7 Aero Peek was left enabled (as suggested in a XBMC forum thread). I tried turning on/off 'Use a fullscreen window rather than a true fullscreen'. None of these worked. I also have the latest graphics driver from Intel's site installed, then done all Windows updates.
So, what the heck is the issue?! I don't notice the tearing issue in the Confluence UI and video playback looks fine in it, Aeon Nox and Ace skins. However, the tearing is very noticeable (see attached screenshots) in Nox and Ace. Please help.
xbmc_nuc_issue1.jpg 161k .jpg file
xbmc_nuc_issue2.jpg 217k .jpg file
xbmc_nuc_issue3.jpg 216k .jpg file
xbmc_nuc_issue4.jpg 194k .jpg file
xbmc_nuc_issue5.jpg 209k .jpg file
Update: spoke too soon, the tearing is happening in Confluence UI as well (looks more like weird horizontal lines here) frown.gif
xbmc_nuc_issue6.jpg 193k .jpg file
ID:	71302   Click image for larger version
ID:	71303   Click image for larger version
ID:	71304   Click image for larger version
ID:	71305   Click image for larger version
Hi-deft Media Keen Videosaurus
Brajesh is offline
Old 08-07-2013, 03:32 PM
josh9000's Avatar
I have the same exact issue on my Panasonic GT30 55".
josh9000 is offline
Old 08-07-2013, 03:36 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I just got the newest Aeon Skin... I will check and see if I have the problem. I am also using the w1070. All of my video settings are at default.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Old 08-07-2013, 03:42 PM
bluechunks's Avatar
Quoted: 85 Post(s)
Liked: 117
There was talk about his over in the huge NUC thread on the XBMC forum. I'm not running windows so I can't test it, but the problem was apparently introduced in the latest Intel video driver. Rolling the driver back to the previous version fixed the issue for those folks. YMMV.
__________
Old 08-07-2013, 03:56 PM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
Thanks... btw, do you also have the latest graphics driver from Intel?
Brajesh is offline
Old 08-07-2013, 04:26 PM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
Thanks much... rolling back to v9.17.10.2932 graphics driver did the trick. Hope Intel is aware of this issue.
Brajesh is offline
Old 08-07-2013, 04:42 PM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
I posted about this in a thread here where I was getting horrizonal and menu bugs. XMBC has issues with the latest intel igpu drivers. This is known and recognized by intel and they said it should be fixed by the next driver update. The solution for gen 3 CPUs is to roll back the driver. For gen 4 haswell, you have nothing to roll back to, but can use the win8 beta driver. IME, however, this trades problems. it fixes the graphics glitch, but breaks my HD audio via HDMI (video still works, but HD audio is listed as unplugged in the setup dialog).
Anthony_Gomez is offline
Old 08-07-2013, 04:53 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I have video driver version 9.17.10.2932 with no problems os tearing at all with Openelec/XBMC on a i3 NUC.
ellisr63 is offline
Old 08-07-2013, 04:56 PM
Quoted: 61 Post(s)
Liked: 184
Old 08-07-2013, 06:21 PM
bluechunks's Avatar
Quoted: 85 Post(s)
Liked: 117
Note that the 3rd page of that thread has links to Intel beta drivers that are reported to fix the problem(s) for Windows 7/8.
The 64-bit version includes:
Intel(R) Graphics Driver: 9.18.10.3214
Intel(R) Display Audio Driver: 6.16.0.3111
__________
Old 08-07-2013, 09:46 PM
TeflonDog's Avatar
http://semiaccurate.com/2013/02/05/intels-nuc-illustrates-why-the-company-struggles-in-a-post-pc-world/
However, they are looking at it from a PC-replacement POV. But they've raised some concerns about video drivers. Are Intel graphics so bad?
TeflonDog is offline
Old 08-08-2013, 12:04 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I've been a firm believer to keep using my Dune media players, but lately, I've been itching at trying HTPC again. I really like this Intel NUC, and I am thinking I might pull the trigger on it with the wife's approval of course. I'm forbidden at the moment to spend anything due to our wedding coming up in 5 weeks lol. I am thinking of selling my Dune TV303D, and replacing it with the NUC. I really like the XBMC look, and my wife would probably use the NUC more then the Dune since she likdes watching her "Days of Our Damn Bring lives," on her laptop. I might be able to program it to be played with XBMC or WMC if possible?
GusGus748s is offline
Old 08-08-2013, 06:11 AM
bluechunks's Avatar
Quoted: 85 Post(s)
Liked: 117
Take everything the author of that website says with a HUGE grain of salt. Note that he even contradicts himself several times in the same article. And yes, the Intel HD graphics are no match for top-of-the-line GPUs from AMD or Nvidia for gaming and some of the CPUs do not support all of the virtual machine functions. But guess what? For HTPC or general desktop use (email, web, Office) those massively powerful GPUs are just sitting there. Meanwhile the NUC, even the inexpensive Celeron w/ HD2000 GPU, includes hardware acceleration for H.264/VC1/MPEG2 and bit-streaming of HD audio codecs for a HTPC rig.
TeflonDog likes this.
__________
Old 08-08-2013, 07:50 AM
GuyLR's Avatar
Charlie at Semiaccurate can have some strong opinions but I think he is essentially right on the NUC's value as an HTPC. He suggests, and I agree, that the upcoming Gigabyte Brix with AMD Kabini's in them will make better sense at getting what you need for an HTPC at an almost reasonable price.
http://semiaccurate.com/2013/06/19/gigabytes-brix-is-a-useful-intel-nuc/
GuyLR is online now
Old 08-08-2013, 08:56 AM
bluechunks's Avatar
Quoted: 85 Post(s)
Liked: 117
I also agree that the AMD version of the Brix could be very interesting for a HTPC. Competition is awesome.
__________
Old 08-08-2013, 10:36 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
Newegg has the NUC with i5 CPU for $379.99. this might be a little over kill, but is never bad to have more CPU power.
http://www.newegg.com/Product/Product.aspx?Item=N82E16856102035&nm_mc=EMC-IGNEFL080813&cm_mmc=EMC-IGNEFL080813-_-EMC-080813-Index-_-MiniBooksizeBareboneSystems-_-56102035-L010A
Old 08-09-2013, 11:59 AM
Popeeta's Avatar
i5 nuc ordered. Countdown to sweet htpc and emulator console starts now!
Also set up to cancel my satellite provider to go ota recording and streaming only with HD homerun and synology NAS.
Popeeta is offline
Old 08-09-2013, 12:16 PM
TeflonDog's Avatar
He's not a good reviewer as he's so overly-biased he fails to grasp what a product review is. It sounds like Intel stole his lunch money (which, is quite possible). ;)He then says the Brix is "a useful Intel NUC" ... because it's cheaper, ignoring that it's got all the same expansion limitations as the NUC. It seems he does not like this category of PC... but it's OK if it's cheap and not Intel. I love these new small form factors. Why do I need so much room for expansion when I can keep most of my data on NAS or cloud storage?
That said, I am no Intel fanboy and will probably choose AMD (as I have in the past) instead. (Even though the ATI Radeon is one of the main problems in my HP Pavilion).
But thanks for the link.
I don't see the GB-XM1 AMD for sale anywhere. The Gigabyte website is only showing Intel options. No word on a release date, eh?
The Brix is also lacking Dual HDMI, which I like about the NUC.
Old 08-09-2013, 12:21 PM
TeflonDog's Avatar
GusGus748s likes this.
Old 08-09-2013, 01:12 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
True very true!!!
Old 08-09-2013, 06:11 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I think if you break your system up like I did you will be fine for years.
I have a Home Automation Server, Media Server (both i3 NUCs), and a Atom for my UnRAID NAS. I think I am fine till 4k is inexpensive. smile.gif
ellisr63 is offline
Old 08-09-2013, 09:12 PM
Carisma's Avatar
Uou
youre using the i3 NUC as a home automation server?
Carisma is offline
Old 08-09-2013, 09:15 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Uou
Yup... I use CQC. I know it is a bit of a overkill but it was mainly to save electricity and space, and I liked the i3 NUC. I figured that if I needed something more later I would have the power to do it.
ellisr63 is offline
Old 08-09-2013, 09:39 PM
Carisma's Avatar
Nice! Never thought about using it as a home automation server before but it does make sense smile.gif
Carisma is offline
Old 08-09-2013, 10:41 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I wanted something that was thrifty on electricity since it is on 24/7... MY CQC Server, Media Server, and NAS consume less than half of what my HTPC did, plus the NUCs are silent and the NAS is quieter too..
ellisr63 is offline
Old 08-10-2013, 12:04 AM
killa2009's Avatar
what do you use cqc server to do? What do people in general use severs to?
