Assassin's Intel NUC Review - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 589 Old 01-28-2014, 12:42 PM
GCS
GCS's Avatar
Quoted: 49 Post(s)
Liked: 32
It's only this model that doesn't support W7 (according to Intel) so look at the other models around.
I still think the NUC is great. The one I did for my sister as her new desktop went just fine and runs circles around anything we have in my office.
XBL Gamertag - blowfish7494
"Pull up your big boy pants and deal with it" - The Wife!
"Put on your man suit and fake it" - The Wife
GCS is offline
post #542 of 589 Old 01-28-2014, 04:21 PM
toohip's Avatar
It now supports Windows 7 with the latest BIOS (21). Im running windows 7 right now. Might have to wait a bit on drivers though.
toohip is offline
post #543 of 589 Old 01-28-2014, 04:30 PM
toohip's Avatar
Originally Posted by Charles R View Post
I looked at Realtek and couldn't find it listed. Now if the generic driver works I can't say... Looking around I saw an ad for the NUC (overseas) which stated Windows 7 drivers will be available in March.
These work fine.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
Win7 and WinServer 2008 R2 Driver 7.078 2014/1/24 887k
Driver_Win7_7078_01212014
toohip is offline
post #544 of 589 Old 01-28-2014, 05:03 PM
Charles R's Avatar
Liked: 536
Originally Posted by toohip View Post
These work fine.
Great! Video drivers (for HD Audio) and it's pretty much there. Last I heard Windows 8.1 still wasn't streaming...
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #545 of 589 Old 01-28-2014, 05:20 PM
toohip's Avatar
Currently trying different video card drives. So far no luck..
My ultimate plan was to run Openelec but till they get that figured out I will keep pursuing Windows 7.
toohip is offline
post #546 of 589 Old 01-29-2014, 05:38 AM
andy987s's Avatar
I installed Ubuntu 13.10 on my DN2820FYKH - everything other than wifi worked out of the box (both on original #15 BIOS and the new #21 release).
I don't use wifi, but you can add the driver with
apt-get install linux-firmware
andy987s is offline
post #547 of 589 Old 01-29-2014, 05:43 AM
toohip's Avatar
I was able to install Openelec using the latest Gotham build. I selected Windows 8.1 in in the UEFI Boot pane and enabled Legacy booting in the BIOS.
http://openelec.tv/forum/20-development-discussion/67846-xbmc-gotham-generic-nightly-builds
IR works great.
I will test HD-Audio tonight.
Were almost there!!
toohip is offline
post #548 of 589 Old 01-29-2014, 07:16 AM
Charles R's Avatar
Liked: 536
Not to steal the NUC's thunder but has anyone seen this guy? Haven't found a review yet...  http://www.asus.com/ASUS_VivoPC/VivoPC_VM40B/
Other than the CPU the specs look great for $289...  http://www.amazon.com/Asus-VivoPC-VM40B-01-ASUS-Desktop/dp/B00GMONZ28
post #549 of 589 Old 01-29-2014, 07:46 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
The C1007U CPU in that ASUS is a nice little CPU/GPU package. It'll do just about anything HTPC except gaming and 3D. It's little brother the C847 could even play high-bit 1080p H.264 and VC-1 without issues. I've built a bunch of systems using the Gigabyte C1007U motherboard and there are a lot of smiling, happy faces enjoying them.
StardogChampion is offline
post #550 of 589 Old 01-29-2014, 02:08 PM
Dark_Slayer's Avatar
Quoted: 658 Post(s)
Liked: 434
I haven't seen that before, but I think that's a pretty attractive setup there with the RAM included as well as AC wifi. I'd probably pull out the 500GB drive and sell it, then boot openelec instead. My only question about it would be the noise, it's clearly not fanless but that 1007 probably doesn't require very much airflow
Dark_Slayer is offline
post #551 of 589 Old 01-29-2014, 03:12 PM
Charles R's Avatar
Liked: 536
I took it for a test drive at Fry's today. Seems nicely built with the top being thin metal and the sides fairly heavy plastic. The top slides off to expose a 3.5" WD drive. Somehow the demo had been upgraded to Windows 8.1 (return perhaps?) and it felt rather snappy.
post #552 of 589 Old 01-29-2014, 04:19 PM
jch1's Avatar
Quoted: 35 Post(s)
How do you all feel about the Brix?
jch1 is offline
post #553 of 589 Old 01-29-2014, 04:32 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
I think it's the ****! (See what I did there?!) Though it's an over-priced design. There haven't really been any thorough reviews and tests of them from what I've seen because they just went wide. AnandTech did an initial write-up at the beginning the month and has promised a more thorough review by the end of the month, which is this week, so we'll have to wait and see. I don't expect anything great from BRIX Pro until the Skylake GPU hits as that is supposed to be Intel's "new GPU architecture" while the current stuff goes all the way back to the original Intel HD Graphics. Gigabyte is now offering BRIX Pro-type units with AMD hardware, so that might tell a bit about where things stand right now.
LexInVA is offline
post #554 of 589 Old 01-29-2014, 04:38 PM
toohip's Avatar
IR works great.
Were almost there!!
HD-Audio is working great along with everything else. Since this is a Gotham build you need to go into Advanced audio settings to enable Audio passthrough and Receiver supports boxes checked.
Menus and navigation are smooth using MQ5 skin.
I'm happy now.
toohip is offline
post #555 of 589 Old 01-29-2014, 04:39 PM
jch1's Avatar
Quoted: 35 Post(s)
Thanks for the quick response. I'm basically trying to determine what unit would best fit my needs for XBMC and/or Plex. It seems like a newer model of the the NUC has had its share of problems as of late, and I'd certainly prefer to avoid similar issues if at all possible.
jch1 is offline
post #556 of 589 Old 01-30-2014, 09:56 AM
Quoted: 658 Post(s)
Liked: 434
I'm happy now.
Can you elaborate a little on your setup?
Did you use a USB3 flash drive for OE?
Are you using a standard WMC remote to control IR?
How much ram did you install?
post #557 of 589 Old 01-30-2014, 04:34 PM
toohip's Avatar
No, Standard USB stick
Harmony Remote - with CIR you can actually power unit off and on.
See below
NUC Kit DN2820FYKH
Openelec - Current Gotham nightly Generic build- Current Intel release would not install correctly.
Logitech Wireless Keyboard. K400
4 gb Crucial Ram. CT51264BF160B
Vertex 2 SSD 60gb
GB Lan
Pulls 10.2 watts running 1080p AVC and HD-audio.
toohip is offline
post #558 of 589 Old 01-30-2014, 04:46 PM
Quoted: 658 Post(s)
Liked: 434
NUC Kit DN2820FYKH
Vertex 2 SSD 60gb
GB Lan
To clarify, are you using the standard usb stick or the Vertex 2 as your OpenELEC boot drive?
post #559 of 589 Old 01-30-2014, 05:06 PM
toohip's Avatar
I used the USB stick to install to my SSD. After install i removed the stick to boot from SSD.
I suppose that if i remove the wireless card im not using i could shave off another .5-1 watts or so.
Update.
Just did another Watt check.
9.7 - 10.0 Watts
toohip is offline
post #560 of 589 Old 01-30-2014, 06:02 PM
ssaeed's Avatar
Guys, how will the nuc DN2820FYKH compare to the asrock ion330? I have the ion330 running ubuntu but wanted something a bit faster. Will the DN2820FYKH run noticeably faster?
ssaeed is offline
post #561 of 589 Old 01-30-2014, 09:40 PM
mrock12's Avatar
IR works great.
Were almost there!!
What did you have to do to get the IR to work?
mrock12 is offline
post #562 of 589 Old 01-31-2014, 04:43 AM
toohip's Avatar
Nothing. IR had worked out of the box for everything i have tried so far.
toohip is offline
post #563 of 589 Old 01-31-2014, 07:45 AM
originalsnuffy's Avatar
Just discovered that the CPU is truly low powered. With foobar 2000, the unit has trouble decoding SACD and DVD audio files in real time using the plug ins.
I am leaning towards not recommending this device.
originalsnuffy is offline
post #564 of 589 Old 02-05-2014, 01:38 PM
ewitte's Avatar
Fry's has a nice price for the 4250 Haswell NUC. I started setting one up with a 120GB EVO and iSCSI recording drive. So far its doing pretty good. Had more pain with Win8.1 almost backed off to windows 7 but ended up solving all my issues. WMC addon broke my activation had to actually call M$ to fix it.
ewitte is offline
post #565 of 589 Old 02-05-2014, 01:46 PM
ewitte's Avatar
I was originally going to replace my main PC huge tower with the NUC now that I have a server but the Echo died and I decided I'd rather hold off for a little bit more GPU power. Currently though I'm only playing one game and I tested on my laptop its completely fine at 1080p high settings on a HD4600 so the HD5000 probably would have handled it just fine windowed at that same res on a 2560x1440 monitor.
ewitte is offline
post #566 of 589 Old 02-07-2014, 10:47 AM
sievers's Avatar
I'm still having issues with my i5 haswell nuc, random crashes. I already returned one, and am having the same issues more or less. Up the thread it was stated that the newer nucs only work with windows 8, though I don't think that applies to the haswell nucs (tho I'm not sure). I'm running windows 7. Starting to think I should just get a copy of windows 8 and try that. I think I can download and try it for free before buying... anyone think that would help? Yes it's an additional cost I wasn't planning on but if it makes this thing work I'll be ok with it.
sievers is offline
post #567 of 589 Old 02-07-2014, 11:39 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
It appears that the new NUCs are having issues since released date. I've been waiting for a while to buy a NUC, but I think I'm probably buy one of the older i3 NUCs. I don't need 3D since I've got a dedicated 3D BD player.
GusGus748s is offline
post #568 of 589 Old 03-05-2014, 06:41 PM
With the new el cheapo units, the key question is ..... what do I want to use the machine for ? For basic audio and video playback it really works well. It only runs out of steam if you want to run more cpu intensive tasks.
It does run quietly and draws little power.
post #569 of 589 Old 03-07-2014, 03:08 PM
mikegno's Avatar
I haven't been able to find an answer to whether you can do a sustained recording of an HDTV stream on an external hard drive using one of the USB 2.0 ports on the older i3 NUC's. I'm getting an HDHomerun prime and need something to stream from it. Looks like any NUC will do. I'm seeing some deals on the older i3 NUC's with only USB 2.0 and am tempted. But I want to be able to do some recording and the mSATA's are limited in size if trying to do a cheap build.. I already have a 1.3 TB USB 3.0 external drive but the transfer rate obviously would be limited by the USB 2.0 port.
Would recording an hour or two of HDTV to an external drive over the USB port work?
mikegno is offline
post #570 of 589 Old 03-07-2014, 03:59 PM
Charles R's Avatar
Liked: 536
USB 2.0 can handle four concurrent recordings and still stream a few shows. For a while I had my Celeron NUC (the older/slower one) running Windows 7/WMC with two HDHomeRuns and it never missed a beat. I use iSCSI to store recordings directly on my NAS which adds to the overhead.
Reply Home Theater Computers
