Assassin's Intel NUC Review - Page 20 - AVS Forum | Home Theater Discussions And Reviews
post #571 of 589 Old 03-07-2014, 08:21 PM
mikegno's Avatar
Thanks for the quick reply. I used to run an instance of Win7 in a virtual machine on my home server and have it record clear QAM (or whatever it's called) channels using an HDHomerun and WMC until Comcast started encrypting everything. The Home server runs on an i3 which had no problems powering everything. The programs would initially get recorded on a virtual hard drive in the Win7 virtual machine and then WMC would move the recordings to a bigger partition on the server. I would just try to do it that way but I have to set up an htpc in the den by the plasma to stream anyway so I am just going to use that if possible.
Thanks again.
Will report back either way.
mikegno is offline
post #572 of 589 Old 03-09-2014, 06:51 PM
Charles R's Avatar
Liked: 649
Originally Posted by mikegno View Post
I haven't been able to find an answer to whether you can do a sustained recording of an HDTV stream on an external hard drive using one of the USB 2.0 ports on the older i3 NUC's.
I know I already answered this but I thought I would post an image for future reference. It's a USB 2.0 drive attached to an i3. There are three recordings and one Xbox extender. As you can see not really a challenge... the tuners are networked HDHomeRuns on the same Gigabit switch.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #573 of 589 Old 03-09-2014, 06:55 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
What is the max bitrate for a TV/Cable recording? Isn't it something like 20mbps? That is only 2.5 MEGABYTES which is nothing for a hard drive. Even if your external hard drive that can only write at 10MB you could theoretically record 4 shows.
Mrkazador is offline
post #574 of 589 Old 03-09-2014, 07:02 PM
Charles R's Avatar
Liked: 649
I posted images showing a few of my locals here...
http://www.avsforum.com/t/1422535/windows-media-center-vs-tivo-premiere#post_22290109
post #575 of 589 Old 04-16-2014, 04:14 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
If anyone is interested, I am selling my i3 NUC setup on ebay. My user name there is the same as here.
lulimet is offline
post #576 of 589 Old 04-16-2014, 04:23 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Copy and paste a link of it.
GusGus748s is offline
post #577 of 589 Old 04-19-2014, 05:16 PM
Porschefan's Avatar
I'm reseaching/planning my first HTPC build and ran across this thread. Is a NUC a viable/good choice for a beginner?
This post at PC Perspective has a chart with prices. I'm trying set something up with the basic purpose of replacing two Comcast DVR's with an HTPC + HD Homerun Prime. Planning on WMC and using the Assassin HTPC blogs as a guide.
Seem like a NUC would have plenty of processing power, but what about storage? I just need something to store recorded TV programs--no big video collection.
So just wondering whether I should pursue this, or concentrate on something more conventional?
TIA for any pointers.
STP
Best regards,
Stephen T. Porter
ABQ, NM
Porschefan is offline
post #578 of 589 Old 04-19-2014, 05:23 PM
Porschefan's Avatar
RE my previous link on the new Intel NUC, just noticed this comment:
April 18, 2014 | 03:23 PM - Posted by Anonymous (not verified)
Do not buy for HTPC because of audio bug. Intel has a beta driver that seems to work at the moment. This bug has plagued the NUC for almost a year now. You can read all about it at https://communities.intel.com/thread/41853?start=45&tstart=0
Issue is if you have the NUC running and the tv/receiver is turned off for a period of time then you turn it back on, the NUC does not have sound until you reboot.
I checked the referenced thread and there does seem to be a fix for it now.
Best regards,
Stephen T. Porter
ABQ, NM
post #579 of 589 Old 12-26-2014, 01:34 PM
Liked: 0
Hi All. Yes, I have read this thread all the way through, and thanks for all the information.
So, I am ready to pull the trigger on a build using this very NUC, intending to run XBMC on Windows 8.1 PRO, mainly for local streaming from NAS, web streaming including NETFLIX, and web browsing. But, I'm a little concerned because the RAM and SSD I have chosen are not on the compatibility list. Does any one have any thoughts on this build:
NUC: Intel DC3217IYE HD 4000 Graphics
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600 Cas Latency 9 1.35V Dual Channel Kit F3-1600C9D-8GRSL
SSD: Intel 530 80GB SSDMCEAW080A401
and a power cord, all for CDN $ 495 including shipping and taxes, from newegg.ca (I would insert the links if I was allowed to do so).
Sudy Nim is offline
post #580 of 589 Old 12-26-2014, 01:43 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
That is the first generation NUC. You need 1.5v memory instead of the 1.35v that you have chosen. Only the second gen NUCs use the lower voltage memory.
And those prices sound high but pretty much everything in Canda costs more than in US so I understand.
That NUC here is $253, the 8GB of 1.5v G.Skill memory is $60, and the Intel 530 msata ssd is $70.
lulimet is offline
post #581 of 589 Old 12-26-2014, 01:49 PM
Liked: 0
Thanks. It was my understanding that, while the newest generation required 1.35V, on the original one could use either 1.5V or 1.35V? At least, that's what the Intel specs. seem to say for this kit, at intel.com/support/motherboards/desktop/dc3217iye/sb/CS-033885.htm.
Sudy Nim is offline
post #582 of 589 Old 12-26-2014, 01:52 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
I tried 1.35v on my NUC (same model you've chosen) and it didn't work for me. I was getting too many BSODs.
lulimet is offline
post #583 of 589 Old 12-26-2014, 01:54 PM
Liked: 0
Yes, completely understand (and not too happy) about the higher prices here. The NUC at newegg.ca is regular $330, on special for $300, with additional $20 instant rebate, so $280. The RAM is $88 (regular price), and the SSD $80 (regular price).
Sudy Nim is offline
post #584 of 589 Old 12-26-2014, 01:57 PM
Liked: 0
Thanks for that info about the 1.35V RAM. I guess it would be a good idea to change it, then.
Is there any advantage, one way or the other, to go with a single 8GB stick versus two 4GB sticks? I went with dual channel for whatever speed increase it might offer, but does one configuration us less power, or generate less heat, than the other?
Sudy Nim is offline
post #585 of 589 Old 12-26-2014, 01:59 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
I haven't done any comparisons but most people agree that it is better to use dual channel memory than single channel even if total memory is the same.
lulimet is offline
post #586 of 589 Old 12-26-2014, 02:02 PM
Liked: 0
How about this RAM:
G.SKILL 8GB (2 x 4GB) DDR3 1600 Cas Latency 9 1.5V Dual Channel Kit F3-12800CL9D-8GBSQ
newegg.ca/Product/Product.aspx?Item=N82E16820231472
Sudy Nim is offline
post #587 of 589 Old 12-26-2014, 02:07 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
Damn, that's $100 with shipping. It should work though.
lulimet is offline
post #588 of 589 Old 12-26-2014, 02:17 PM
Liked: 0
Yep. Wanted to order everything from one source, so there would only be a single shipping charge, but ends up newegg.ca is applying two shipping charges anyway (the cart split the order into two parts, and I have no idea why, unless one part is coming from a different source than the others, but they are all sold by newegg). But with the current special on the NUC, these are about the best prices I could find in Canada.
So, with the new RAM (and I hope I can now supply links), the build is:
NUC: Intel DC3217IYE HD 4000 Graphics http://www.newegg.ca/Product/Product...-002-_-Product
RAM: G.SKILL 8GB (2 x 4GB) DDR3 1600 Cas Latency 9 1.5V Dual Channel Kit F3-12800CL9D-8GBSQ http://www.newegg.ca/Product/Product...82E16820231472
SSD: Intel 530 80GB SSDMCEAW080A401 http://www.newegg.ca/Product/Product...82E16820167196
Look okay? Is that a decent SSD?
Sudy Nim is offline
post #589 of 589 Old 05-07-2015, 09:17 AM
MrMcCrackin's Avatar
Quoted: 20 Post(s)
New thread created
MrMcCrackin is offline
Reply Home Theater Computers
