AMD FX or A series ? - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2013, 02:53 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
What's the difference between AMD FX or APU?
If FX uses integrated graphics and A series has built in APU graphics, what's the difference between these?
Mike99 is offline
Old 03-02-2013, 06:38 AM
FantaXP7's Avatar
Quoted: 42 Post(s)
Liked: 35
I believe the FX series doesn't have integrated graphics but would rely on whatever graphics may be included on a mobo.
The APU has it built into the CPU like most newer Intel chips.
FantaXP7 is offline
Old 03-02-2013, 09:21 AM
DDK65JAG's Avatar
Don't know for sure, but the last integrated graphics on any of my AMD boards was HD4290 graphics
on an SB850 chip, not bad & does the job for me.
If memory serves, FM1 compatible A processors have 6xxx series graphics and FM2 compatible A
processors have 7xxx series graphics. Either being far more powerfull than the integrated(onboard)
graphics.
DDK
DDK65JAG is offline
Old 03-02-2013, 12:42 PM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I think you are correct that the FX does not have integrated graphics.
I don't know where I got that idea. Maybe because some or all of the Athlons & Phenoms do. My desktop with a quad core Athlon has integrated HD4200 graphics so I presumed anything newer and/or more powerful did.
What is the difference between an Athlon with integrated graphics and an A-series CPU?
Mike99 is offline
Old 03-02-2013, 01:22 PM
StardogChampion's Avatar
Quoted: 92 Post(s)
Liked: 160
If it's an AM2/2+/3/3+ then the GPU is on the motherboard's northbridge (e.g. Athlon, Phenom, FX)
If it's an FM1/FM2 then the GPU is part of the CPU (e.g. A4/A6/A8)
Your quad-core Athlon does not have an integrated GPU. The HD4200 GPU is part of the motherboard's northbridge chipset.
StardogChampion is offline
Old 03-02-2013, 03:02 PM
AVS Club Gold
renethx's Avatar
Quoted: 245 Post(s)
Liked: 401
HD 4200: UVD2, 40 Radeon cores
Llano: UVD3 (Divx, MVC), 160/320/400 Radeon cores
Trinity: UVD3, WLIW4 architecture, 128/192/256/384 Radeon cores
renethx is offline
