Windows Platform Update (Optional) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-02-2013, 12:31 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
http://support.microsoft.com/kb/2670838
This showed up in Windows Update. Has anybody installed it? Is it working okay?
This article describes a platform update for Windows 7 Service Pack 1 (SP1) and Windows Server 2008 R2 SP1. This update improves the features and performance of the following components:
Direct2D
DirectWrite
Direct3D
Windows Imaging Component (WIC)
Windows Advanced Rasterization Platform (WARP)
Windows Animation Manager (WAM)
XPS Document API
H.264 Video Decoder
JPEG XR codec
Sammy2 is offline
post #2 of 13 Old 03-02-2013, 12:53 PM
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I have it installed.  It looks like general directx maintenance update; fixing some bugs and new features for software developers.
MKANET is offline
post #3 of 13 Old 03-02-2013, 01:01 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay. I use LAV et al for decoding video but I was wondering if this update was going to change the registry and break my custom codecs that work very well for my on my HTPC right now.
Sammy2 is offline
post #4 of 13 Old 03-02-2013, 02:11 PM
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I use LAV filters, reclock, and a bunch of other filters like most people here.  I didnt notice anything different after the update.  It may have fixed some minor issues and new features for developers; but I didnt notice that ether.  Id say its pretty safe.
MKANET is offline
post #5 of 13 Old 03-02-2013, 02:14 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Cool thanks.
Sammy2 is offline
post #6 of 13 Old 03-02-2013, 02:45 PM
Postmoderndesign's Avatar
Quoted: 216 Post(s)
Liked: 85
+1
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #7 of 13 Old 03-02-2013, 05:10 PM
sydlexius's Avatar
It's a prerequisite for installing IE10 on Windows 7. It's a backport of features from Windows 8 to fully support some of its features.
sydlexius is offline
post #8 of 13 Old 03-02-2013, 06:42 PM
vladd's Avatar
Liked: 39
vladd is offline
post #9 of 13 Old 03-02-2013, 07:37 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Thans vladd! It looks like it could be an issue using the WMC player but right now I am playing an mkv with h.264 in it using MPC-HC with madVR and LAV just fine. I am a bit concerned going forward if h.264 is ever used by Charter in this area. It seems to effect users of NextPVR. I've looked into that before but due to DRM I don't use it. Is this mostly in Europe.
(BTW, sorry about all that racous in the Cinavia thread about viruses and such.. I was on a rant about something totally different there..)
Sammy2 is offline
post #10 of 13 Old 03-02-2013, 07:47 PM
vladd's Avatar
Liked: 39
If you are using anything other than the MS DTV-DVD Video Decoder for H.264 (LAV in your case) in your player of choice, you are not affected at all by the update. Some people were using the MS decoder with NextPVR and they are the only ones (ie: NextPVR users) affected.
Re the other thread: I get where you are coming from and totally agree with you. I was just trying to prove a point in regards to Cinavia... lost cause that it is.
vladd is offline
post #11 of 13 Old 03-02-2013, 08:11 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So if Charter starts using h.264 then I may have a problem with the player in WMC for Live/Recorded TV playback just like NextPVR users in Europe are experiencing now?
(I'll be clear, Cinavia is not a virus.)
Sammy2 is offline
post #12 of 13 Old 03-02-2013, 08:18 PM
vladd's Avatar
Liked: 39
You shouldn't have a problem. I should have said that "if you are using the MS decoder in a third party (non MS) player" like MPC or NextPVR. The decoder still works in WMC/WMP.
As a side note, you can't use the MS decoder in third party appls in Windows 8.
vladd is offline
post #13 of 13 Old 03-02-2013, 08:19 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay. Perfect.
Sammy2 is offline
Reply Home Theater Computers
