Dust - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-03-2013, 09:09 AM - Thread Starter
josh_parker123's Avatar
After getting my new origenae m10 I have a few concerns about dust getting into the case. Maybe I'm just noticing it more but the case always seems very dusty and there are 2 pretty large holed areas on the top, does anyone know of any good covers or things that attract dust to stop it being an issue ?
josh_parker123 is offline
post #2 of 16 Old 03-03-2013, 01:22 PM
Postmoderndesign's Avatar
Quoted: 216 Post(s)
Liked: 85
A clean room for the computer will help. Vacuum and use one of those swifter dusters. Open up the computer from time to time and blow it out with canned air.
You do need to have air circulate through the computer. Heat can kill a computer faster than dust.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #3 of 16 Old 03-03-2013, 01:37 PM - Thread Starter
I do all of the above but the room is just prone to dust, I'm sure I will come across some filters etc , I was just looking for suggestions
post #4 of 16 Old 03-03-2013, 06:57 PM
vladd's Avatar
Liked: 39
Do you have a fan in the side vent? If you do, set it to pull air into the case. This will create over-pressure and the air will be vented through the top and back. You would then just need to put a filter on the side covering the fan. I've found this to be the best solution with my cases and I have 4 cats.
vladd is offline
post #5 of 16 Old 03-03-2013, 07:53 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
My heatsink: http://club.myce.com/f1/who-has-most-hair-lint-331711/#post2679520
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 16 Old 03-03-2013, 08:48 PM
vladd's Avatar
Liked: 39
Not going to join another forum and post twice just to see an image, sorry.
vladd is offline
post #7 of 16 Old 03-03-2013, 08:49 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
staknhalo is offline
post #8 of 16 Old 03-03-2013, 09:06 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Sorry, forgot they changed the rules (although MYCE is a great forum for storage and optical disk related info). Here's what 3 cats and keeping the tower on the floor will do:
olyteddy is offline
post #9 of 16 Old 03-03-2013, 10:25 PM
vladd's Avatar
Liked: 39
Yup, that looks familiar!
Re MyCE: I browse it from time to time, I've just had no need to join yet. (I spend way too much time on forums as it is)
vladd is offline
post #10 of 16 Old 03-04-2013, 02:56 AM - Thread Starter
Sounds like a good idea I fancied replacing the side fan anyway, bit of a silence but. Shame silent 60mm fans aren't really an option
post #11 of 16 Old 03-04-2013, 05:28 AM
cybrsage's Avatar
Liked: 154
Just be thankful you never open the case to see this:
No, it is not mine or anyone's I know.
cybrsage is offline
post #12 of 16 Old 03-04-2013, 05:52 AM
lovekeiiy's Avatar
Liked: 30
holy bat turds, that's nasty. I wonder if the machine even worked. I thought the PC I picked up used at county surplus was bad, LOL.
lovekeiiy is offline
post #13 of 16 Old 03-04-2013, 10:01 AM
vladd's Avatar
Liked: 39
You win.
vladd is offline
post #14 of 16 Old 03-04-2013, 10:14 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That takes the cake.. There's probably some in there actually!
This reminds me, I haven't cleaned the filters on my PC in about 3 or 4 months. It is probably about time to do that and maybe blow out the HTPC but it doesn't get as bad as it is up off the floor in an enclosed cabinet. I have 120 mm fans ventilating the cabinet but suppose those could use some filters. I just haven't got to that yet.
Sammy2 is offline
post #15 of 16 Old 03-04-2013, 12:16 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Holy crap! That looks like the inside of the Bat Cave! eek.gif That should be titled "Revenge of the Dust Bunnies!"
captain_video is offline
post #16 of 16 Old 03-04-2013, 08:41 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
I took home a pile of PCs from my daughters' school last year to diagnose them. Most of them looked like that picture above with all the dust. No surprise there were so many dead PSUs.
StardogChampion is offline
Reply Home Theater Computers
