HELP! Not getting any HD audio with my HTPC - AVS Forum | Home Theater Discussions And Reviews
Old 03-08-2013, 05:24 PM - Thread Starter
EyesOnly2k's Avatar
So heres the deal... I just got a blu-ray drive for my HTPC, but I can't get ANY HD audio to out to my receiver. Here is what I'm using for hardware.
MOBO: Asrock Z77 Extreme 4
GPU: EVGA GTX 660 SuperClocked
CPU: Intel Core i5 3330
RAM: 8GB
BD: Pioneer BDC-207BDK
OS: Windows 8 Pro
Software: Total Media Theatre 5 (installed as trial) & MakeMKV
Audio Receiver: Onkyo HT-R280 (from Walmart)
Here is what i've tried.
HDMI from GPU to Receiver with nvidia HD audio drivers
HDMI from MOBO to Receiver with Realtek drivers
HD audio enabled in BIOS
HD audio disabled ind BIOS
Tried switching HDMI cables out
Tried changing HDMI ports on my receiver
Tired uninstalling and reinstalling all drivers
HD-Audio plays fine from same HMDI port using my PS3
No matter what I do, I can't get ANY of the HD audio formats to show up as available in the sound settings. All it gives me is DTS, Dolby Digital and Dolby Digital Plus. When I play a blu-ray using TMT 5 (checked settings, and choose the HD audio stream) it outputs DTS-HD Master Audio as just regular DTS and Dolby-HD as PCM (weird.. right?)
I'm attaching screen shots of what my audio properties look like. I hope some can help me figure this out... it's driving me crazy!
EyesOnly2k is offline
Old 03-08-2013, 05:33 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
That's a HTIB,
Most of them cannot accept and decode bitstreamed HD Audio. Are you 100% sure it can accept a bitstream HD Audio stream?
assassin is online now
Old 03-08-2013, 06:11 PM - Thread Starter
EyesOnly2k's Avatar
I'm not 100% sure. I can't find any confirmation on it, but that seems like very likely explanation. Let's say that is whats happening, besides investing in a new receiver, is there any other way to make it work? Thanks!
Old 03-08-2013, 06:14 PM
kegobeer's Avatar
No, you won't get HD audio without a receiver capable of decoding it. You'll just have to enjoy the audio you have currently unless you upgrade your receiver.
kegobeer is offline
Old 03-08-2013, 06:19 PM - Thread Starter
EyesOnly2k's Avatar
That's kinda what I figured. Thanks for confirming for me!
Old 03-10-2013, 06:41 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
According to the manual on the O it does the HD formats... you mentioned having the latest driver for your video card but do the nVidia cards pass HD audio?
Andrew Hornfeck is offline
Old 03-10-2013, 08:15 PM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
My gtx 570 don't do hd audio formats either use the intel hd graphics instead and that will solve your prob.
ikkuranus is offline
Old 03-10-2013, 08:30 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
So nobody (except Andrew Hornfeck) reads the manual? From page 6:
AV Receiver HT-R280
HDMI (Ver.1.4 with Audio Return Channel, 3D), Deep-Color, x.v.Color, Lip Sync, DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus, DSD and Multi-CH PCM
But I don't know why there is an EDID problem.
renethx is offline
Old 03-11-2013, 11:37 AM
vladd's Avatar
Liked: 39
It's a 5.1 system and is most likely missing the 8ch LPCM SAD. EDID override is most likely needed.
vladd is offline
