Hdhomerun question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 03-13-2013, 03:17 AM - Thread Starter
ryu4000's Avatar
I have 4 hdtv in my house was wondering how many tuners do i need been looking into doing this but still a newbie at it this is just going be for watching tv no need to use dvr really.
ryu4000 is offline
post #2 of 20 Old 03-13-2013, 05:54 AM
gewbert's Avatar
Liked: 27
Well that depends on your viewing habits. Are all 4 TVs ever in use? If so, you may want to wait until the new 4-tuner HDHomeRun announced in January comes out (sometime this summer, no exact date yet). Or you'll need to get 2 3-tuner boxes and will need to use Tuner Salad (Windows 7 only, though there are some work arounds for Win 8 I've seen) to increase the 4-tuner limit in Windows Media Center.
The other think to keep in mind is you'll need a box at each TV, whether it's a HTPC (Zotac, Intel NUC, or actual computer) or an extender (Xbox 360) to access the Homerun.
Hope that helps!
gewbert is offline
post #3 of 20 Old 03-13-2013, 06:27 AM
TornadoTJ's Avatar
Quoted: 1631 Post(s)
Liked: 511
You also need to say whether you are watching from OTA (antenna), cable requiring cable card, QAM, etc.
For me I have a three tuner CableCard version, and a dual antenna version.
But like Gewbert says, depends on your habits.
TornadoTJ is offline
post #4 of 20 Old 03-13-2013, 06:35 AM - Thread Starter
ryu4000's Avatar
guess i be waiting for 4 tunner version then and there all 4 in use most of the time.
ryu4000 is offline
post #5 of 20 Old 03-13-2013, 06:37 AM
gewbert's Avatar
Liked: 27
You could also look into the Ceton infiniTV which has 4 tuners. The only catch is I think you have to assign the tuners to a TV/box and that only works in Win. 7 (I don't have so I'm not 100% familiar on the process).
gewbert is offline
post #6 of 20 Old 03-13-2013, 06:44 AM
TornadoTJ's Avatar
Liked: 511
4 OTA channels, 4 cable channels... ? You may need two solutions.
post #7 of 20 Old 03-13-2013, 06:59 AM
mdavej's Avatar
Quoted: 2131 Post(s)
Liked: 942
For live OTA you don't need anything. All your TVs can do that right now.
mdavej is offline
post #8 of 20 Old 03-13-2013, 07:47 AM
TornadoTJ's Avatar
Liked: 511
post #9 of 20 Old 03-13-2013, 10:13 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
Don't forget if you're implementing a DVR solution you'd need a tuner for each active recording.
JDLIVE is offline
post #10 of 20 Old 03-13-2013, 11:02 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
We have 6 TV's and 4 CableCard tuners (Ceton InfiniTV4) and 4 ClearQAM (2x HomeRun duals) for grand total of 8 tuners. We have had 2 or 3 instances when all tuners were in use.... I am really looking forward to InifniTV 6 with 6 CableCard tuners.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #11 of 20 Old 03-13-2013, 11:06 AM
mdavej's Avatar
Liked: 942
I have to ask why bother with an HD HomeRun at all if you only want live tv? Am I missing something?
mdavej is offline
post #12 of 20 Old 03-13-2013, 11:07 AM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
How many extenders can be hooked up with a single PC?
amarshonarbangla is offline
post #13 of 20 Old 03-13-2013, 11:27 AM
mdavej's Avatar
Liked: 942
I don't think there is a practical limit. But Microsoft only supports a max of 5 simultaneous sessions. You'll need a hefty amount of RAM for that, 8GB at least. But I have to say this is one of the most Rube Golberg solutions I've seen in this forum in a long time.
mdavej is offline
post #14 of 20 Old 03-13-2013, 12:01 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Good point. It does say no DVR doesn't it. But if you want to pause LiveTV then you sort of need one. My question is, after being exposed to a PVR would anyone go back to not using one?
Sammy2 is offline
post #15 of 20 Old 03-13-2013, 03:59 PM
mdavej's Avatar
Liked: 942
As soon as you pause live TV, then you're using the DVR. I don't know why anyone would have a DVR and not use it, or how anyone could use a DVR and ever go back to life without one, as you said.
ryu4000, why do you think you need a Homerun for live tv? Why do you not want to use a DVR? Are you going to use extenders, and if so, what do you have in mind? How are you going to get the signal from the PC to all your tv's (wired ethernet, Moca, powerline ethernet)? Is your HTPC going to serve purposes other than just live TV?
mdavej is offline
post #16 of 20 Old 03-13-2013, 04:02 PM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
Unless some of the TVs are actually computer monitors or you want to be able to record shows.
skibum5000 is offline
post #17 of 20 Old 03-13-2013, 04:03 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
The OP said he has four HDTV's and doesn't want a DVR.
Sammy2 is offline
post #18 of 20 Old 03-13-2013, 07:59 PM - Thread Starter
ryu4000's Avatar
Yea it be cabletv and just don't care too much for recording shows really i buy mostly blu-ray and rip them to current htpc.The reason i choose the hdhome run is cause it allows me to not have to worry with pcie slot cause one of the extenders doesn't have pcie to begin with it's one of the zotac zbox.all 4 hdtv with there extenders will all be wired ethernet to a hub or switch.
ryu4000 is offline
post #19 of 20 Old 03-14-2013, 09:18 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
PCs can't be Media Center extenders. If you use all extender setup, they can even share tuners if they are watching the same channel.
Foxbat121 is online now
post #20 of 20 Old 03-14-2013, 09:23 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
With an HDHR you can get the same thing for OTA but cannot share the same "DVR" which apparently isn't a concern of the OP as the use of a DVR isn't a requirement.
Sammy2 is offline
Reply Home Theater Computers
