Build Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-15-2013, 01:25 PM - Thread Starter
gostillerz's Avatar
Hi guys. I'm researching into building an HTPC, but never done it before. I'm using an 09 Mac Mini, but it won't do everything I want.
I'm big into retro games with emulators, basic games like Civ V, Sim City. Play 1080p from an external drive, lossless audio, play blurays, will have a tv tuner to record basic cable, stream stuff etc.I'm using XMBC on the Mac, but open to other options of course. Here's what I was looking at getting. Any advice is greatly appreciated.
CPU
AMD A4-5300
Motherboard
MSI FM2-A55M-E33
RAM
Corsair 2x4GB
Bluray
Liteon IHES112-04
SSD
Corsair 120GB refurb
Power Supply
Seasonic S12II 380B
TV Tuner
Hauppauge WinTV-HVR-2250
HDD
Seagate 3TB external (using with Mac now)
Case
NMediaPC 1000B, LCD module, IR receiver
Remote
Harmony 880
How would this work, anything I'm missing or chose wrong? Cost adds up to about $650 without Windows 7.
It's these cans! He hates these cans!
gostillerz is offline
post #2 of 15 Old 03-15-2013, 08:15 PM
tomandbeth's Avatar
Only thing that looked ugly was the refurbed SSD. Yeah, I know, usually they aren't a problem
but with 120-128G SSD going for $80 new??? Why bother getting a refurb? Especially since
your other components are very solid choices?
mi dos pesos.
tomandbeth is offline
post #3 of 15 Old 03-15-2013, 08:22 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
I don't like the A4. The A6 is as anemic as I will go for an AMD build. Just my opinion of course.
assassin is offline
post #4 of 15 Old 03-16-2013, 10:34 AM - Thread Starter
gostillerz's Avatar
Granted I only looked on Newegg, but prices I saw were around $120 for SSD's. I'll keep looking around. How about the A6-5400K CPU? I originally wanted an Intel i3, but I'm trying to keep costs down as much as possible.
post #5 of 15 Old 03-16-2013, 11:01 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
A6-5400K is more or less equivalent to Core i3 in gaming performance, neither of which may be a good choice for games like Civ V and SimCity, depending on the resolution and settings.
renethx is offline
post #6 of 15 Old 03-16-2013, 11:26 AM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Not sure I agree with you there Renethx...
Passmarks:
i3 3220: 4282
A6-5400K: 2174
One of these is much better/easier to slap in a more powerful card later if the gaming experience is lacking or if it needs to be improved.
assassin is offline
post #7 of 15 Old 03-16-2013, 11:44 AM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
CPU
AMD A4-5300
Motherboard
MSI FM2-A55M-E33
RAM
Corsair 2x4GB
Bluray
Liteon IHES112-04
SSD
Power Supply
Seasonic S12II 380B
TV Tuner
Check Techbargains Storage section for good SSD deals (usually before Slickdeals or any other site posts) http://www.techbargains.com/catsearch.cfm/0_11_0
Right now you could get a 120GB Samsung 840 for $85 with free shipping if you use the 15OFF coupon code LINK
I prefer the HDHR Prime as a tuner
Either processor can handle retro emulators (2D) easily. Check out RetroArch. Word in the forums is that libretro support may be builtin to XBMC
Dark_Slayer is offline
post #8 of 15 Old 03-16-2013, 12:36 PM - Thread Starter
gostillerz's Avatar
Thanks for putting up with my noobness. There's so many options for parts, it's pretty damn overwhelming. I was reading more, and someone suggested this:
CPU: AMD A10 5800K
Motherboard: MSI FM2-A75IA-E53
I like that the motherboard has built in wifi and Bluetooth, and the reviews for the CPU were very good. It's more than I was looking to spend, but $100 isn't gonna kill me if the performance justifies the added loot. The first of many more questions. Will the PC recognize the external HDD I'm using on the Mac? I just have mp3, FLAC, and movie files on it, but don't know about how the drive is formatted.
post #9 of 15 Old 03-16-2013, 01:15 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
CPU: AMD A10 5800K
A10 5800K is a good choice. Its gaming performance is better than HD 6570 and GT 630. Video playback performance is the best in this class.
But, why a mini-ITX mb? Unless you decide to go with a mini-ITX case, you'd better choose a microATX mb.
renethx is offline
post #10 of 15 Old 03-16-2013, 01:25 PM - Thread Starter
gostillerz's Avatar
Okay, I'll go with that CPU. For cases, I was looking at either nMediaPC 1000B or 5000B. Could you suggest a motherboard that'll make more sense? I like the wifi and Bluetooth built in, but it's not necessary by any means.
post #11 of 15 Old 03-16-2013, 01:28 PM
Nebiroth's Avatar
Liked: 30
Any special reason you are sticking with AMD? AFAIK the A10 is ahead only for onboard graphics and overclocking but behind on general CPU performance, at the expense of being a relative power hog with the concomitant problems of heat
Purely IMHO, for games, a discrete card will always serve better and the 7760D onboard the A10 is not the equivalent of a Radeon 77xx card.
Nebiroth is offline
post #12 of 15 Old 03-16-2013, 01:46 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Great post.
assassin is offline
post #13 of 15 Old 03-16-2013, 02:55 PM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Passmarks:
i3 3220: 4282
A6-5400K: 2174
Just curious, why would one of those be easier to slap in a more powerful card later?
Mike99 is offline
post #14 of 15 Old 03-16-2013, 03:11 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Simply A10 is the best in price/performance in this price range (CPU + GPU). Or do you know any better choice? Power consumption..., well, there is not significant difference between A10 and Intel+HD 6570 (at most 10-20W difference).
Not entirely true. A10+HD 7760D is better than the combination of any CPU+HD 6570/GT 630 in gaming and video playback. Of course if he is willing to spend more than $200 on CPU+GPU, Core i3+HD 7750 or higher is obviously better in performance, but that's not the present case:
renethx is offline
post #15 of 15 Old 03-16-2013, 03:24 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Because for gaming one is going to have a very weak CPU that will limit some games and some settings much more than the other one (hint: the weaker one begins with A and ends with D) given the same graphics card.
assassin is offline
Reply Home Theater Computers
