asrock fma85x itx aftermarket cooler... owner users please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-18-2013, 12:35 AM - Thread Starter
hazna's Avatar
Running a10 5700 in a isk300-150 . The stock cooler is overwhelmed. The back of the mono does not work for backplate coolers.
Anybody else with a similar setup?
hazna is offline
post #2 of 10 Old 03-18-2013, 06:37 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I mention this often but an a8/a10 in a small case is not a good idea. From my experience you are going to need a large aftermarket cooler which will necessitate a larger case.
assassin is offline
post #3 of 10 Old 03-18-2013, 07:03 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Try to downclock CPU. CPU is less important in video playback, GPU is everything.
renethx is offline
post #4 of 10 Old 03-18-2013, 08:50 AM - Thread Starter
hazna's Avatar
The case is behind my tv Vesa mounted.
hazna is offline
post #5 of 10 Old 03-18-2013, 08:52 AM - Thread Starter
hazna's Avatar
Renethhx,
Is there a guide for under clocking?
Actually the temps are ok around 41 just the noise is bothering...
hazna is offline
post #6 of 10 Old 03-18-2013, 08:55 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I don't think this is going to work well for you given the amount of heat and lack of airflow generated by the HTPC and HDTV in a cramped space.
assassin is offline
post #7 of 10 Old 03-18-2013, 09:25 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Renethhx,
Have you clicked the hyperlink in my my post? (There is nothing terribly difficult; just move the slide bar to the left a little bit. smile.gif)
Have you adjusted the fan speed in BIOS > H/W Monitor > CPU Fan Setting? (Select "Automatic mode" and set "Target CPU Temperature to, say, 60 and "Target Fan Speed" to, say, Level 3).
renethx is offline
post #8 of 10 Old 03-18-2013, 12:35 PM - Thread Starter
hazna's Avatar
Sorry hyperlink did not show on my phone. Thanks.
The biggest problem I have is mounting an after market cooler. The back of the matherboard has chips where the backplate is supposed to go.
hazna is offline
post #9 of 10 Old 03-18-2013, 12:58 PM - Thread Starter
hazna's Avatar
isn't 60c high?
hazna is offline
post #10 of 10 Old 03-18-2013, 02:13 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Maximum operating temperature of A10-5700 is 71.3°C. So 60°C is pretty safe. (If the temperature reaches 71.3°C, CPU will throttle down automatically to avoid damage anyway.)
renethx is offline
Reply Home Theater Computers
