Problems installing MCE 7 Reset Toolbox - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-18-2013, 09:28 AM - Thread Starter
ZxRO's Avatar
So I am attempting to install MCE 7 Reset Toolbox so I can further customize my WMC experience. When I attempt to install it, however, the EULA extends down over the "Accept" button, making it impossible to accept the EULA. I've tried in multiple resolutions, to no avail. Anyone else experience this issue? Is there a workaround? I attempted this with the 64 bit version..
ZxRO is offline
post #2 of 5 Old 03-18-2013, 10:08 AM
bryansj's Avatar
Quoted: 1421 Post(s)
Liked: 645
What is your screen resolution? Maybe it is too narrow. You could try hitting the Win key plus an arrow key.
bryansj is offline
post #3 of 5 Old 03-18-2013, 10:14 AM - Thread Starter
ZxRO's Avatar
Yeah I'm dumb, I didn't think to attempt to use the keyboard to select it. I'll try that tonite. As for resolutions, I've tried several, and even at max 1080p resolution, it remains the same. I'll go the keyboard route. Still, terrible UI, I hope the actual program works better.
ZxRO is offline
post #4 of 5 Old 03-18-2013, 10:23 AM
bryansj's Avatar
Liked: 645
I run it at 1080p and don't recall the issue you have. Maybe you have your font size increased or something? I also may have RDP to install it.
bryansj is offline
post #5 of 5 Old 03-18-2013, 10:26 AM - Thread Starter
ZxRO's Avatar
Yeah it's probably something dumb like that. Assuming I have keyboard control on the installer, I'm sure that will fix the issue. I'll try it first thing tonite when I am back in front of my tv.
Sometimes it just takes another brain to solve even the dumbest of problems.
It probably is a font size issue. I'm sure I blew up icons and fonts and whatever. It's hard to read text on a 61" 1080p with default Windows settings.
ZxRO is offline
Reply Home Theater Computers
