New to htpc. Can a 150watt psu power my set up? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-19-2013, 05:16 PM - Thread Starter
Oxn
Oxn's Avatar
So i have considered building a very powerful htpc using the igp on either an ivybridge or haswell.
So here is the plan with the Origen M10 case that comes with 150watt psu
I5 3570k or 4570k (may underclock pending how much power is needed) 77 or 83 max watts
Mobo
8 gigs of ram
Blu ray drive
1 ssd
1 hdd
Will it run on 150 watt if i keep everything stock, and max it load under gaming?
Oxn is offline
post #2 of 12 Old 03-19-2013, 09:54 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #3 of 12 Old 03-20-2013, 07:21 AM - Thread Starter
Oxn
Oxn's Avatar
Any other input or is this definitive?
Reminder i want it to work under load
Oxn is offline
post #4 of 12 Old 03-20-2013, 07:24 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Definitive.
StardogChampion is offline
post #5 of 12 Old 03-25-2013, 07:45 PM - Thread Starter
Oxn
Oxn's Avatar
Can someone explain it to me how? I used a power calculaator and it jus doesnt add up
Oxn is offline
post #6 of 12 Old 03-25-2013, 07:52 PM
Quoted: 93 Post(s)
Liked: 160
From my own experience having built dozens upon dozens of mini-ITX systems I can tell you those power calculators just don't work when it comes to the small PSUs and modern systems.
What would the power calculator say the PSU needed for this?
i3-2120T
H61 motherboard
8GB RAM
128GB SSD
BD-ROM drive (slot-load)
AMD HD6670 GPU
Measures 110W at full load with a 120W power supply -- fully stable -- no shutdowns or anything. I ran Prime95 and Furmark and then played Steam demos all evening.
My guesstimate with the i5-3570K and your components you might see 100W max but most of the time 25W-45W.
I have customers running i7-3770S on 120W PSUs.
I save the 150W power supply for the AMD A10 builds.
post #7 of 12 Old 03-25-2013, 08:14 PM - Thread Starter
Oxn
Oxn's Avatar
The power calculator i used shows actually around 140w
Oxn is offline
post #8 of 12 Old 03-25-2013, 08:15 PM - Thread Starter
Oxn
Oxn's Avatar
I just dont want to buy a $350 case just to see it run unstable
Oxn is offline
post #9 of 12 Old 03-26-2013, 09:41 AM
user4avsforum's Avatar
150w is more than you need.
For reference I am running a mini-ITX with the following:
I7 3770S (65w TDP)
DH77DF Mobo
8 gigs of ram
Blu ray drive
1 ssd
1 hdd
Keyboard, Mouse, Webcam, BT USB, z-wave USB
All running on a CityNet 150w PicoPSU fed by a 120w AC-DC adapter.
Peak power at the wall as measured by Kill-a-watt meter never ever EVER... gets close to 100w - in fact I don't think I have ever seen it exceed 80w at the wall.
Intel Desktop utilities show steady voltage, a good indication that the PSU is not overloaded.
user4avsforum is offline
post #10 of 12 Old 03-26-2013, 12:18 PM - Thread Starter
Oxn
Oxn's Avatar
Thanks for the reply.
Its just a little confusing to me because I run just about the EXACT same set up on my main PC as the one I plan for my HTPC and the only difference being the 6870 gpu in my PC, and that has a 550watt psu in it.
I know it will never hit close to 550watts, but there is just such a huge power difference.
Oxn is offline
post #11 of 12 Old 03-27-2013, 01:45 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
When running all of the following programs simultaneously,
- Prime95 (CPU stress test)
- MSI Kombustor (GPU burn-in test)
- AnyDVD HD ripper (making BD drive and HDD busy)
the power consumption of the total system is ~125W DC (yup, DC is what you need to know when selecting a PSU). The system:
- Core i5-3570K (non-oc)
- DDR3-2133 4GB x 2
- Z77 mb
- a SSD
- a HDD
- a BD driver
This is an extreme case. I can say 150W PSU is enough.
renethx is offline
post #12 of 12 Old 03-27-2013, 04:53 AM - Thread Starter
Oxn
Oxn's Avatar
Thanks now i feel confident in making the purchase in a month
Oxn is offline
Reply Home Theater Computers
