Is my video card not strong enough or is it my HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-23-2013, 02:40 PM - Thread Starter
itsblown's Avatar
Im trying to stream 720p movies from my computer to my samsung 42 inch plasma. I just purchased a 40ft HDMI cable from amazon it was a cheap no name 23 dollar one. When I hook up the 40ft hdmi between my video card( info on the video card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127515) on my computer and my t.v. my video card will recognize the t.v. and notice that it is there but my t.v. says there is is no signal source Even when I have things calibrated on my computer to project to two displays.. I tried hooking up the HDMI cable between my xbox and my tv to make sure it works and it worked fine with no display issues. So then I tried hooking it up between my laptop and the t.v., and the t.v. said their was no signal source.
What do I need to make it work is my video card not strong enough? Do I need an HDMI repeater or signal booster?
itsblown is offline
post #2 of 7 Old 03-24-2013, 01:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Have you installed the nVidia drivers and configured them for 720p?
Sammy2 is offline
post #3 of 7 Old 03-24-2013, 01:26 PM - Thread Starter
itsblown's Avatar
yes all drivers are installed properly and after checking to see if it works with a shorter HDMI cable it does...
itsblown is offline
post #4 of 7 Old 03-24-2013, 01:26 PM - Thread Starter
itsblown's Avatar
itsblown is offline
post #5 of 7 Old 03-24-2013, 02:01 PM
mdavej's Avatar
Quoted: 2132 Post(s)
Liked: 942
40ft is pushing the limits of HDMI. I would definitely try a shorter cable.
mdavej is offline
post #6 of 7 Old 03-24-2013, 02:46 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
^^ What Dave says! If you need to go 40' then you should use a better cable, maybe a monoprice redmere cable.
Sammy2 is offline
post #7 of 7 Old 03-24-2013, 03:48 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Agreed, I tried pushing my HTPC through a 50' HDMI and it "worked" but it was iffy. I changed to a 35' and no more issues.
Dropkick Murphy is offline
Reply Home Theater Computers
